MHB Radical Equation Solution: Simplifying and Transposing for Accurate Results?
  • Thread starter Thread starter paulmdrdo1
    Radical
The equation $\sqrt{x} - \frac{2}{\sqrt{x}} = 1$ requires careful manipulation to find the correct solution. Transposing terms incorrectly can lead to errors, as seen when $1$ was dropped from the equation. The correct approach involves multiplying both sides by $\sqrt{x}$, resulting in $x - 2 = \sqrt{x}$. Squaring both sides will yield potential solutions, which must be verified against the original equation to avoid extraneous results. Ultimately, the solution process emphasizes the importance of maintaining all terms throughout the manipulation.
paulmdrdo1
$\sqrt{x}-\frac{2}{\sqrt{x}}=1$
transposing $\frac{2}{\sqrt{x}}$ to the right-side
$\sqrt{x}=\frac{2}{\sqrt{x}}$ multiply by $\sqrt{x}$
I get,
$x=2$ is my solution correct? if not please explain why. thanks!
Mathematics news on Phys.org
I get,
It is not right. becuase you dropped the 1
you will get
$\sqrt{x}=1+ \frac{2}{\sqrt{x}}$
but this approach shall not help
1st step is to multiply by $\sqrt{x}$ to remove redical from denominator
I get,
you can solve it in that way :
$$\sqrt{x}-\frac{2}{\sqrt{x}}=1$$
multiply by $$\sqrt{x}$$ and moving the other term to the other side :
$$x=1+2=3$$
hope that is right ..
$$x=1+2=3$$
No, that isn't right, either.
If we multiply the equation:
$\sqrt{x} - \dfrac{2}{\sqrt{x}} = 1$
by $\sqrt{x}$, we obtain:
$x - 2 = \sqrt{x}$
Now, the best thing to do is square both sides. This will introduce an "extraneous" solution, so be sure to test both answers against the original problem.
I suggest letting $x=t^2$ if you don't prefer working with radicals , just like me.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
