Solving recurence T(n)=T(n-1)+O(n lg n)
  • Thread starter Thread starter kasper_2211
The recurrence relation T(n) = T(n-1) + O(n lg n) can be solved using the method of substitution and unfolding. The analysis reveals that the total cost can be approximated by T(n) ≤ c n^2 lg n, leading to the conclusion that T(n) = O(n^2 lg n). The base case checks confirm that the solution holds for T(1) = 1, and the induction hypothesis supports the derived bounds, although further refinement is needed to eliminate lower-order terms.
  • Understanding of recurrence relations and their solutions
  • Familiarity with Big O notation and asymptotic analysis
  • Knowledge of logarithmic functions, specifically log base 2
  • Experience with mathematical induction techniques
  • Study the Master Theorem for solving recurrences
  • Learn about the method of iteration for recurrence relations
  • Explore advanced topics in algorithm analysis, focusing on time complexity
  • Investigate techniques for eliminating lower-order terms in asymptotic bounds
Students and professionals in computer science, particularly those studying algorithms, data structures, and complexity analysis, will benefit from this discussion.
kasper_2211
I am trying to solve this here recurrence : T(n)=T(n-1)+O(n lg n).
I am trying to do it by guessing the solution, and then use substitution to prove it right. I think that I am way off though...
lg n = log_2 n
Intuitively the "height" of the recursion will be h=n-2, i.e there will be n-1 levels. Level 0 has a cost of n lg n and Level n-1 will have cost T(1). If i sum the cost's, and try to bound by an arithmetic series i arrive at a guess of n^2.
Now, by substitution i guess that it will hold for some constant c >= (lg n+n-2)/2
Hmm... Thank's in advance for any help...
Here is a, maybe, better attempt at a solution.
1. Homework Statement
I am trying to do it by guessing the solution, and then use substitution to prove it right. I think that I am way off though...2. Homework Equations
lg n = log_2 n3. The Attempt at a Solution
First i try to 'unfold' the recursion,
T(n) = T(n-1) + c n lg n
= c n lg n + T(n-1)
=c n-1 lg n-1 + T(n-2)
=c n-1 lg n-1 + c n-2 lg n-2 + T(n-3)
= c n-1 lg n-1 + c n-2 lg n-2 + c n-3 lg n-3 + ... + T(1)
Since this is some decreasing series i try to bound it like so,
T(n) = c n lg n + c n-1 lg n-1 + c n-2 lg n-2 + c n-3 lg n-3 + ... + T(1) <= c n lg n + c n lg n + c n lg n + ... + T(1)
Now since there is approximately n terms this becomes,
T(n) <= c n^2 lg n
So my guess is that the solution is T(n) = O(n^2 lg n)
Does the above reasoning make any sense?
So guessing at O(n^2 lg n)
Assuming that T(1) = 1
base case 1 : 1 <= 1 lg 1 = 0 -> fails
base case 2 : T(1) + 2 lg 2 <= 4 lg 2 <=> 2 <= 4 -> OK
Now assume that for 2 <= k < n : T(k) <= c k^2 lg k
Induction, (d is supposed to be the constant hidden inside O(n lg n))
T(n) = T(n-1) + d n lg n
<= c (n-1)^2 lg (n-1) + d n lg n by I.H
<= c n^2 lg n + d n lg nNow I am a little stuck...I guess that somehow in the limit c n^2 lg n + d n lg n <= c n^2 lg n, but i don't think i can use that...Also, it looks almost correct but i need to get rid of the lower order term d n lg n. Is this possible?
