Is sqrt(4) Equal to +2 or -2 and Where Is the Error in My Calculation?
  • Thread starter Thread starter luxiaolei
The discussion centers on the confusion surrounding the square root of 4, specifically whether it equals +2 or -2. The key error identified is in the misuse of the property that allows the separation of square roots, which only holds true when both factors are non-negative. While both +2 and -2 are solutions to the equation x^2 = 4, the notation sqrt(4) specifically refers to the principal square root, which is +2. The misunderstanding arises from incorrectly applying the square root properties in the calculations. Ultimately, sqrt(4) is defined as +2, not -2.
luxiaolei
2 = sqrt(4) = sqrt(-1*-1*4) = sqrt(-1)*sqrt(-1)*sqrt(4) = -1*sqrt(4) = -2 ?
Where am I wrong? sqrt(4) = +2 or -2 in the last step? but see sqrt(4)=-1*sqrt(4), still wrong..
Thanks in advance
Mathematics news on Phys.org
Feldoh said:
2 = |sqrt(4)|
Thanks!,how silly am I...gosh...
Thanks in advance
The real problem here lies in the first step, not the last. 2 is a solution to √4, but is not the solution. Your conundrum has simply re-stated that -2 is also a solution to √4. This string of equations does not prove that 2 = -2 (obviously), only that the solution to √4 is non-unique. Good luck!
Thanks Unit91Actual!
x^2 = 4 has two solutions, but sqrt(4) means the positive solution of this equations.
The other one is -sqrt(4).
2 = sqrt(-1 * -1 * 4) is OK, but the next step is not since sqrt(A*B) = sqrt(A) * sqrt(B) is only valid if A and B are >= 0
Good point.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
