Solving the Mystery of Light Pressure | Physics Forum
  • Thread starter Thread starter coki2000
    Light Pressure
coki2000
Hi PF,
I have a question about light pressure: Let's take a laser beam. Each photon in the laser beam has a momentum p=h/λ.
If photons have pressure, dp/dt must be non-zero but, it is zero.
Where do I make mistake?
Thank you for answers.
What makes you think dp/dt is zero?
Do you just mean that the photon has a constant momentum as the beam travels through space? If so, then the answer is: the change in momentum does not happen when the photon is just hurtling through space, it happens when the photon hits a piece of matter and interacts with it. Even a plain old billiard ball rolling across a table has a constant momentum--it's when it hits the other balls that its momentum changes.
Oh, okey. Thank you for your answer :) I understand.
pressure of light is owed to it's magnetic field.when light will fall on a charged particle ,the electric field of light will give a motion in \vec{E} direction and then the magnetic field will act .it is easily shown by the curl of (v×B) that the force is in direction of propagation.(it does not depend on the sign of charge)
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
