Solving the PDE 1-d Heat Equation for a Flipped Rod
The discussion revolves around solving the one-dimensional heat equation for a rod with varying initial and boundary conditions. Participants explore how the problem changes when the rod is flipped, affecting the temperature distribution over time.
  • One participant describes the initial conditions for the heat equation when the rod is not flipped, with temperatures at the ends being 0 degrees at x=0 and 100 degrees at x=L.
  • Another participant notes that when the rod is flipped, the initial condition changes to a temperature distribution from 100 degrees at x=0 to 0 degrees at x=L.
  • A participant inquires about combining the two cases, asking how to set up the problem if the rod is flipped after some time, leading to a new set of initial conditions.
  • One participant clarifies the distinction between boundary conditions and initial conditions, emphasizing that the initial condition cannot be changed after it is set.
  • Another suggestion is made to use step functions for boundary conditions, which could introduce generalized functions like delta functions into the equation, potentially simplifying the problem.
Participants generally agree on the definitions of boundary and initial conditions, but there is no consensus on how to approach the problem of combining the two cases or the implications of flipping the rod.
There are unresolved aspects regarding the specific mathematical setup required for combining the initial conditions and the implications of changing boundary conditions after a certain time.
mskisoc
regarding 1-d Head Equations on rods. I am aware of how to long a rod with length x=0 to x=L. and initial conditions of u(0,t)=0 degrees and u(L,t)=100 degrees. But how does the problem change if before t=0 the rod at x=0 was at 100 degrees and x=L was at 0 degrees. So at time=0 the rod was flipped over. Any help setting this up would be great!
In the first case your initial condition is u(x,0) is a straight line between (0,0) and (L,100) and in the second case it goes from (0,100) to (L,0).
So, how would you set up to solve the problem if the two cases were combined. For example the rod is sitting in a certain set of initial conditions and then the rod if flipped 180 degrees so now it is in a different set of initial conditions and then I am interested in finding out what the temperature distribution would be after that one flip occurred.
OK, let's get the terminology straight; I think I misunderstood you at first. The conditions on u(0,t) and u(L,t) are boundary conditions, not initial conditions. The initial condition u(x,0) = f(x), which needs to be specified to have a well posed problem. It is the temperature at t = 0 along the rod and you don't get to change it.
So I guess you want to let it run until some time t0 > 0 and then change things. What you can't change is the initial conditions. You can change the temperatures at the ends. Is that what you are trying to describe? If so, you could work the problem in two parts. Use the first solution up until t0, then use u(x,t0) as the initial condition and solve again with the new boundary conditions.
You can also write your boundary conditions with step functions, then generalized functions will enter your equation ( a delta function). I think it will be much more interesting and perhaps even faster :)
  • · Replies 36 ·
