Solving this equality. Then simple plot.
  • Thread starter Thread starter rcmango
    Plot
The discussion revolves around solving the inequality 7/2x >= -1/4. Initially, there was confusion regarding the interpretation of the equation, particularly whether x was in the denominator. After clarifying the equation, the correct steps led to the solution x >= -1/14. Participants confirmed that this solution is valid and that it includes x=0, extending to infinity on a number plot. The importance of proper notation to avoid misinterpretation was emphasized throughout the conversation.
rcmango
7/2x >= -1/4
then put it on a number plot.
7x/7 >= -2/4 = -1/2
-1/2 *7/1 = -7/2
x>= -7/2 and I'm not sure if I'm even correct for that answer, and I have to put it on a number plot.
rcmango said:
7x/7 >= -2/4 = -1/2
How did you get this? You could show your steps to help troubleshooting.
If that /7 is just a typo: What did you do afterwards?
The result is wrong.
Just to make sure: Your original equation is ##\frac{7}{2}x \geq -\frac{1}{4}##, so x is not in the denominator?
rcmango said:
7/2x >= -1/4
We're uncertain as to what you mean by 7/2x. A literal interpretation using operator precedence would be (7/2) * x. Others might incorrectly interpret this as 7/(2x). What did you mean?
The way this equality is written is correct.
So i reworked the problem, and I get this answer instead.
2* 7/2*x >= -1/4 *2
7x >= -1/2
7x/7 >= -1/2 / 7/1
x>= -1/14
which on a number plot should be about 0 to wherever (infinity)? including 0.
2* 7/2*x >= -1/4 *2
Again, you need to be sure to add brackets where necessary because 7/2*x can be confused as 7/(2x). In this case, I'd just go ahead and write 7x/2.
rcmango said:
7x >= -1/2
7x/7 >= -1/2 / 7/1
x>= -1/14
What you have is correct and yes, it'll include x=0 and yes it'll go all the way to infinite. You can try it out for yourself as well! Plug in x=0 for
7x/2 >= -1/4
And see if the inequality holds.
Yes it holds.
and agreed 7x/2,
thanks for all the help.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
