Solving Wave Packet Problem: Tips & Guide
  • Thread starter Thread starter tornpie
    Wave Wave packet
tornpie
I was wondering if anyone can give me some assistance on a homework problem. Here it is,
Consider a wave packet defined by
<br /> \begin{equation}<br /> \vec{A}(\vec{r},t)=\int \hat{\mathcal{A}}(\vec{k}-\vec{k_0})<br /> \frac{e^{i(\vec{k}\cdot\vec{r}-\omega(k)t)}}{(2\pi)^{3/2}}d\vec{k}<br /> \end{equation}<br />
where
<br /> \hat{\mathcal{A}}(\vec{k}-\vec{k_0})<br />
is a function that is peaked at \vec{k}=\vec{k_0}.
(a) Show that this packet can be written in the form
<br /> \begin{equation}<br /> \vec{A}(\vec{r},t)=e^{i(\vec{k_0}\cdot\vec{r}-\omega(k_0)t)}\mathcal{A}(\vec{r}-v_gt)+\cdots<br /> \end{equation}<br />,
where \vec{v}_g=\vec{v}_{\mathrm{group}}=\vec{\nabla}_k\omega<br /> (k)|_{k_0} is the group velocity and \mathcal{A}(\vec{r}-\vec{v}_g t) is a function that is peaked at \vec{r}=\vec{v}_gt Hint: expand \omega(k) around \vec{k}_0
(b) Show that for a wave packet not to "spread", i.e., not change its shape from that given by \mathcal{A}(\vec{r}), it is required that \vec{v}_{\mathrm{group}}=\vec{v}_{\mathrm{phase}}. Here \vec{v}_{\mathrm{phase}} is the phase velocity \vec{v}_{\mathrm{phase}}\equiv\omega/k.
(c) As a consequence of the condition \vec{v}_\mathrm{phase}=\vec{v}_\mathrm{group} show that \omega=kc which holds for light in a vacuum. Then deduce that the wave equation \square\vec{A}=0 follows.
(d) Suppose we had \omega(k)=bk^2, where b is some constant. Would the phase and group velocities be the same? What differential equation would you deduce? Would the wave packet maintain its shape?
(a) First, Taylor expand \omega(k) as \omega(k) = \omega(k_0) + \vec{\nabla}_k\omega(k)|_{k_0} \cdot (\vec{k}-\vec{k_0}) + \cdots
Then insert this Taylor expansion, shift dummy variable \vec{k}=\vec{k&#039;}+\vec{k_0} and use the all-important expression of the Dirac peak as its Fourier transform :
=\int \hat{\mathcal{A}}(\vec{k&#039;})<br /> \frac{e^{i\left[(\vec{k&#039;}+\vec{k_0})\cdot\vec{r}-[\omega(k_0) + \vec{k&#039;} \cdot \vec{\nabla}_k\omega(k)|_{k_0} ]t\right]}}{(2\pi)^{3/2}}d\vec{k&#039;}+\cdots
=e^{i(\vec{k_0}\cdot\vec{r}-\omega(k_0)t)}<br /> \int \hat{\mathcal{A}}(\vec{k&#039;})<br /> \frac{e^{i\left[\vec{k&#039;}\cdot (\vec{r}- \vec{\nabla}_k\omega(k)|_{k_0}t)\right]}}{(2\pi)^{3/2}}d\vec{k&#039;}+\cdots
=e^{i(\vec{k_0}\cdot\vec{r}-\omega(k_0)t)}<br /> \int \hat{\mathcal{A}}(\vec{k&#039;})<br /> \frac{e^{i\left[\vec{k&#039;}\cdot (\vec{r}-\vec{v}_gt)\right]}}{(2\pi)^{3/2}}d\vec{k&#039;}+\cdots
\vec{A}(\vec{r},t)=<br /> e^{i(\vec{k_0}\cdot\vec{r}-\omega(k_0)t)}\mathcal{A}(\vec{r}-\vec{v}_gt)+\cdots
(b) I need to lower the level of rigor in order to save my time. Damn latex :wink:
\vec{A}(\vec{r},t)=<br /> e^{i(k r-\omega t)}\mathcal{A}(r-v_gt)+\cdots
The wave packet will not spread if
\vec{A}(r,t)=\vec{A}(r+\delta r,t + \delta t) where \delta r = v_g \delta t. It follows that the argument of \mathcal{A} is automatically unchanged. So you only need to ensure the invariance of the exponanetial's argument :
k r-\omega t = k (r+\delta r)-\omega (t + \delta t) from which k\delta r -\omega\delta t =0 and hence \frac{\delta r}{\delta t}=\frac{\omega}{k}=v_g
(c)For light in vacuum, v_g=c so \omega = k c
From the invariance of \mathcal{A}, you only need to work with the exponential (again) when you deal with differential equations.
You can readily see that the operator (adjust in case you use a different metric signature) \square = \frac{1}{c^2}\frac{\partial^2}{\partial t^2}-\frac{\partial^2}{\partial r^2}=\frac{\omega^2}{c^2}-k^2=0
(d) With this other dispersion relation, the velocities become unequal. v_p=\omega/k is always valid, but v_g = \frac{d\omega}{d k}=b k.
The new differential equation can be expected to be
\frac{1}{b^2}\frac{\partial^2}{\partial t^2}-\frac{\partial^4}{\partial r^4}=0 and the wavepacket will spread.
This is not a great do for me today. I abandonned my fight against the craniale-size/intelligence lobby, and I forgot the basic rule in homework help : provide only hints[/i] not answers... I am sorry, I shall better go sleeping before making another mystake.
Thanks a million. Don't worry about ruining it for me. I will learn each step. I need to learn this packet stuff in a hurry for the future homeworks and tests.
I gave it a pretty fair shot, and I was close to getting it.
You're welcome. It took me a little while, but it was worth for me too. Except that, i am not absolutely certain for the last question, especially the differential equation.
Quite a problem to be on Homework #1 lol.
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
