Integrating Trigonometric Functions with Multiple Substitutions
In summary: Looks very good to me. Great job!...Thanks pranav.My approach for (I) one$\displaystyle = \int\sqrt{\frac{1-\cos x}{1+\cos x}}\cdot \frac{1}{\sqrt{\cos x+2}\cdot \sqrt{\cos x}}dx$$\displaystyle = \int\frac{1-\cos x}{\sin x}\cdot \frac{1}{\sqrt{\cos x+2}\cdot \sqrt{\cos x}}dx$$\displaystyle = \int\frac{1}{1+\cos x}\cdot \frac{1}{\sqrt{\cos x+2}\cdot \sqrt{\cos x}}\cdot \sin
juantheron
247
[1] $\displaystyle \int\sqrt{\frac{\csc x-\cot x}{\csc x+\cot x}}\cdot \frac{\sec x}{\sqrt{1+2\sec x}}dx$
[2] $\displaystyle \int \frac{3\cot 3x - \cot x}{\tan x-3 \tan 3x}dx$
Thanks pranav I have edited it.
jacks said:
[1] $\displaystyle \int\sqrt{\frac{\csc x-\cot x}{\csc x+\cot x}\cdot \frac{\sec x}{\sqrt{1+2\sec x}}}dx$
I guess the forum requires to show some attempt on the problem.
For the first one, can you re-check with the source? I suspect that $\sec(x)/\sqrt{1+2\sec(x)}$ belongs outside the square root.
Pranav said:
I guess the forum requires to show some attempt on the problem...
Yes, our goal is to help with problems, and when no work or thoughts are given, we can't really do that effectively. This does not mean however that you (or anyone) cannot give hints to get the OP started if you so desire. :D
Nice to know that we are allowed to give hints even when no work is shown. I will be posting some problems which I couldn't really attempt. I mean I have no idea where to begin with them so a push in the right direction would be greatly appreciated. :)
In the event that you post a problem, and you are having trouble even beginning the problem, as long as you indicate this in your opening post, then our helpers know where to start with giving help. What we discourage is the posting of problems with no indication of where to begin giving help.
Sorry friends
Yes pranav it is outside the square root.
$\displaystyle = \int\frac{1}{1+\cos x}\cdot \frac{1}{\sqrt{\cos x+2}\cdot \sqrt{\cos x}}\cdot \sin xdx$
Now Let $\cos x = t^2$ Then $\sin xdx = -2tdt$
$\displaystyle = -\int\frac{1}{1+t^2}\cdot \frac{1}{\sqrt{t^2+2}}\cdot \frac{1}{t}\cdot 2tdt$
$\displaystyle = - 2\int\frac{1}{\left(1+t^2\right)\cdot \sqrt{t^2+2}}dt$
Now i have edited it.
Now Help me
For (II) one
$\displaystyle \int\frac{3\tan 3x -\tan x}{\tan x- 3\tan 3x}\cdot \frac{1}{\tan x\cdot \tan 3x}dx$
$\displaystyle = -\int\cot x \cdot \cot 3xdx$
Now Help me
Thanks
jacks said:
Sorry friends
$\displaystyle = \int\sqrt{\frac{1-\cos x}{1+\cos x}}\cdot \frac{1}{\sqrt{2\cos x+1}\cdot \sqrt{\cos x}}dx$
$\displaystyle = \int\frac{1-\cos x}{\sin x}\cdot \frac{1}{\sqrt{2\cos x+1}\cdot \sqrt{\cos x}}dx$
Nope, this is incorrect. How do you get this?
Hint: Use $\cos(x)=2\cos^2(x/2)-1=1-2\sin^2(x/2)$.
For (II) one
Incorrect. Its $3\tan(x)-\tan(3x)$ in the numerator.
Next, can you express $\tan(3x)$ in terms of $\tan(x)$?
Thanks pranav.
Now Let $\displaystyle t = \frac{1}{u}$, Then $\displaystyle dt = -\frac{1}{u^2}du$
$\displaystyle = -\int\frac{u^3}{\left(1+u^2\right)\sqrt{1+2u^2}} \cdot\frac{1}{u^2}du = -\int\frac{u}{\left(1+u^2\right) \sqrt{2\left(u^2+1\right)-1}}du$
Now Let $u^2+1 = v^2$ , Then $2udu = 2vdv\Rightarrow udu = vdv$
Is it Right or not
Thanks pranav
$\displaystyle \int\frac{3\cot 3x -\cot x}{\tan x-3\tan 3x}dx = \int\frac{3\tan x-\tan 3x}{\tan x-3\tan 3x}\cdot \frac{1}{\tan x\cdot \tan 3x}dx$
Using $\displaystyle \tan 3x = \frac{3\tan x-\tan^3 x}{1-3\tan^2 x}$
$\displaystyle = \int\frac{1-3\tan^2 x}{3-\tan^2 x}dx = \int\frac{3\left(3-\tan^2 x\right)-8}{3-\tan^2 x}dx$
$\displaystyle = 3\int 1dx -8\int\frac{1}{3-\tan^2x}dx$
Now Let $\tan x= t$ and $\displaystyle \sec^2 xdx = dt\Rightarrow dx = \frac{1}{1+\tan^2 x}dt = \frac{1}{1+t^2}dt$
$\displaystyle = 3x-8\int\frac{1}{\left(1+t^2\right)\cdot \left(3-t^2\right)}dt = 3x+8\int\frac{1}{\left(1+t^2\right)\cdot \left(t^2-3\right)}dt$
$\displaystyle = 3x+8\cdot \frac{1}{4}\int\frac{1}{t^2-3}dt-\frac{8}{4}\int\frac{1}{1+t^2}dt$
$\displaystyle = 3x+2\cdot \ln \left|\frac{t-\sqrt{3}}{t+\sqrt{3}}\right|-2\cdot \tan^{-1}\left(t\right)+\mathbb{C}$
$\displaystyle = 3x+2\cdot \ln \left|\frac{\tan x-\sqrt{3}}{\tan x+\sqrt{3}}\right|-2\cdot \tan^{-1}\left(\tan x\right)+\mathbb{C}$
jacks said:
Thanks pranav.
Not correct still.
$$\sqrt{\frac{1-\cos(x)}{1+\cos(x)}} \neq \frac{1-\cos(x)}{\sin(x)}$$
I don't see how you get this.
jacks said:
Thanks pranav
Good! ;)
Looks very good to me. Great job! :)
To Pranav
$\displaystyle \sqrt{\frac{1-\cos x}{1+\cos x}} = \sqrt{\frac{1-\cos x}{1+\cos x}\times \frac{1-\cos x}{1-\cos x}} = \sqrt{\frac{\left(1-\cos x\right)^2}{\sin^2 x}} = \left|\frac{1-\cos x}{\sin x}\right| = \frac{1-\cos x}{\sin x}$ for $x\in \left(0,\pi\right)$
jacks said:
To Pranav
I am very sorry to mislead you. I posted my reply in the morning when I was in hurry to leave for the tuition. I realized it on my way there. I am going to check your work again.
Very sorry again.
Okay, your approach for 1 in #8 looks good so far but I suspect you will have to use one more substitution after the last substitution you have presented. What I had in my mind was the following:
Rewrite:
$$\sqrt{\frac{1-\cos(x)}{1+\cos(x)}}=\tan(x/2)$$
$$\sqrt{\cos(x)}=\sqrt{2\cos^2(x/2)-1}$$
$$\sqrt{\cos(x)+2}=\sqrt{2\cos^2(x/2)+1}$$
So we have the following integral:
$$\int \frac{\tan(x/2)}{\sqrt{2\cos^2(x/2)-1}\sqrt{2\cos^2(x/2)+1}}dx=\int \frac{\tan(x/2)}{\sqrt{4\cos^4(x/2)-1}}dx$$
$$=\int \frac{\tan(x/2)\sec^2(x/2)}{\sqrt{4-\sec^4(x/2)}}dx$$
Now use the substitution, $\sec^2(x/2)=t \Rightarrow \sec^2(x/2)\tan(x/2)dx=dt$.
Hence, our integral transforms to:
$$\int \frac{dt}{\sqrt{4-t^2}}$$
The above integral is quite straightforward.
I hope that helped. :)
1. What is an indefinite integral?
An indefinite integral is a mathematical concept that represents the antiderivative or the reverse of differentiation. It is a way to find the function whose derivative is the original function.
2. How do you solve an indefinite integral?
To solve an indefinite integral, you must use the fundamental theorem of calculus, which states that the integral of a function is equal to the difference between the antiderivative at the upper and lower limits of integration. You can also use integration techniques such as substitution, integration by parts, or partial fractions to solve indefinite integrals.
3. What is the difference between definite and indefinite integrals?
The main difference between definite and indefinite integrals is that a definite integral has specific limits of integration, while an indefinite integral does not. In other words, a definite integral gives a numerical value, while an indefinite integral gives a general function.
4. How can indefinite integrals be used in real life?
Indefinite integrals have many real-life applications, especially in physics and engineering. They are used to calculate displacement, velocity, and acceleration in calculus-based physics problems. They are also used in economics to model and predict changes in variables such as cost and demand.
5. Can indefinite integrals be solved analytically?
In most cases, indefinite integrals can be solved analytically using integration techniques. However, there are some functions that cannot be integrated analytically, and numerical methods must be used to approximate the solution. Additionally, some indefinite integrals may result in complex or irrational numbers that cannot be expressed in a simple form.
  • Calculus
  • Calculus
  • Calculus
  • Calculus
