What Are Direction Cosines in Light Scattering Theory?
  • Thread starter Thread starter iLIKEstuff
Direction cosines are the cosines of the angles that a line makes with the coordinate axes, representing the orientation of a unit vector in three-dimensional space. In the context of light scattering theory, they are crucial for calculating the polarizability of particles smaller than the wavelength of light. The polarizability is expressed as a function of these direction cosines, specifically in relation to the electric field vector E_0 and the particle's orientation. The propagation direction of the incident light does not affect the value of polarizability, which is solely determined by the alignment of E_0 with the particle. Understanding direction cosines is essential for accurate calculations in Rayleigh scattering theory.
iLIKEstuff
in using rayleigh scattering theory to calculate the polarizability of particles of arbitrary forms with sizes smaller than the wavelength, my text entitled "light scattering by small particles" by van de hulst states
"{|\alpha|}^{2} is defined by {|\alpha|}^{2} = {l}^{2} {|\alpha_1|}^{2} + {m}^{2} {|\alpha_2|}^{2} + {n}^{2} {|\alpha_3|}^{2} and l,m, n are the direction cosines of E_0 with respect to the three main axes of the polarizability tensor.
THe directions appearing in this problem must be clearly distinguished. The value of |\alpha| is determined by the orientation of E_0 with respect to the particle; the direction of propagation of the incident light is irrelevant. "
my question: what are direction cosines? (if you know a better way of calculating polarizability, please let me know!)
thanks guys.
Science news on Phys.org
The unit vector pointing in a given direction can always be written as
cos(\theta)\vec{i}+ cos(\phi)\vec{j}+ cos(\chi)\vec{k}
where \theta, \phi, and \chi are the angles a line in that direction would make with the x, y, and z-axes respectively. Those cosines are the "direction" cosines. They are simply the x, y, and z components of a unit vector in a given direction.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
