Some questions about 3D environment
  • Thread starter Thread starter baby_1
    3d
The discussion addresses fundamental concepts in 3D and 2D geometry, clarifying that a vector has a specific length while a line extends infinitely. To find a vertical or perpendicular vector on a surface, one must consider the equation of the surface, such as Ax + By + Cz = D for planes, where perpendicular vectors are multiples of <A, B, C>. The conversation emphasizes that the angle between two vectors cannot be determined solely by their magnitudes, as vectors of the same length can point in various directions, leading to different angles. Understanding these distinctions is crucial for working with geometric concepts in both 2D and 3D environments. Overall, the thread provides insights into vector and line relationships in geometry.
baby_1
Hello
I have some question that i confused to know them
1-what is difference between Vector and Line in 3D and 2D?
2-how can find the vertical vector on a surface or line?
3-how can find the angle between two vector or line only with their size?( i do it with Inner Product equation but without the Inner Product value how can do that
Thanks
Mathematics news on Phys.org
baby_1 said:
Hello
A vector has a specific length, a line extends infinitely. Also you can add vectors and multiply vectors by numbers. Lines have no "algebra".
What do you mean by "vertical"? Do you mean perpendicular? How you would find it depends on how you are given the surface or line. We can write a plane in three dimensions as Ax+ By+ Cz= D. In that case, any perpendicular vector is a multiplie of <A, B C>. If the "surface" is not a plane, perpendicular vectors will vary from point to point. A line, in two dimensions, written as y= ax+ b, has perpendicular vector <a, -1>.
You don't! Two vectors with the same lengths can have many different directions and so many different angles between them. The size of vectors is completely irrelevant to the angle between them.
Thanks
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
