Some Questions pestering me , Help
  • Thread starter Thread starter daemonakadevil
Negative current indicates the flow of current in the opposite direction, which can be visualized through a sine wave graph for AC current. In a parallel circuit with resistance and capacitance connected to a DC battery, current initially flows through both arms, but once the capacitor charges, the flow to the capacitance arm ceases. Voltage can be likened to pressure in a water system, where higher voltage increases current flow through narrower resistors. Understanding these concepts is crucial for analyzing circuit behavior and electromagnetic wave production. Overall, these discussions clarify fundamental electrical principles and their implications in circuits.
daemonakadevil
Hello friends i am weired in these questing , please help! .
1. What does negative current means , you can see AC current as sin wave graph means
ac goes +ve 1st then -ve & same process keep going , if you're going to say that -ve current means flow of current in charge flow direction then it means charge does vibrating which means wire is producing electromagnetic waves ?? right
2. suppose that if have a resistance & a (resistance+capacitance) in parallel
if we connect a dc batter in that || circuit . from which arm will current flow?
(from resistance arm or (resistance+capacitance) arm) & why?
3. what does voltage means ? , if voltage is high what & why happens in circuit??o:)
Thanks a lot! :-p
1. Yeah, negative current just means opposite direction (eg. to the arrows on some diagram).
2. At first (the current alternates from off to on) some current will flow to both arms, but once the capacator charges the flow to that arm will stop.
3. If you consider an analogy to water flow, voltage/potential is a bit like pressure, it increases the current through narrow resistors..
And yeah, an ac does produce electromagnetic waves...
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
