Some questions regarding a differential equation
nothingisreal
Hello,
I am new here. I hope I am posting my problem at the right place.
I need some urgent help regarding the following differential equation:
A[itex]\frac{d^{2}y}{dx^{2}}[/itex]+B[itex]\frac{dy}{dx}[/itex]=f(x,[itex]\lambda[/itex])...(1)
where, A and B are constants. x and [itex]\lambda[/itex] are independent.
I have solved the equation analytically and the solution is a function of x and [itex]\lambda[/itex], i.e y(x,[itex]\lambda[/itex]).
Afterwards, to obtain y(x) [i.e to make it [itex]\lambda[/itex] independent], I have integrated the solution over a region of [itex]\lambda[/itex], i.e [itex]\int{y(x,\lambda)}[/itex]d[itex]\lambda[/itex]=y(x) ...(2)
My question is - can I integrate the term f(x,[itex]\lambda[/itex]) over a region of [itex]\lambda[/itex] before solving the eqn (1)? i.e if I replace f(x,[itex]\lambda[/itex]) by [itex]\int{f(x,\lambda)}[/itex]d[itex]\lambda[/itex] = f(x) in eqn (1) and solve the following equation:
A[itex]\frac{d^{2}y}{dx^{2}}[/itex]+B[itex]\frac{dy}{dx}[/itex]=f(x) ...(3)
Is it a correct way to solve (1)?
I have solved the eqn (3). But, the solution (y(x) curve) is completely different than (2).
Which method should I use (first or second method)? Any explanation of getting different results would also help me. Please pardon my ignorance - I am new in this field.
Many many thanks in advance...
Yes if x and lambda are independent, then it does not matter if you integrate before or after you solve the ode.
