Something that bugs me about concentration
  • Thread starter Thread starter Hitman123
    Concentration
When removing 100 mL from a 500 mL bottle of vinegar containing 5% acetic acid, the concentration of acetic acid remains at 5% in both the removed portion and the remaining solution. Concentrations are consistent in a well-mixed solution, meaning that regardless of the volume taken out, the percentage of acetic acid does not change. This principle can be illustrated with a population analogy, where if 50% of a country's population is female, the same percentage applies to any subset of that population, such as a city.
Hitman123
This may sound ridiculous to the elite here, but if I had a bottle with 500mL of vinegar where 5% was acetic acid. If I removed 100 mL will there still be 5% acetic acid there then?
Chemistry news on Phys.org
Hi Hitman123, welcome to PF!
Concentrations are relative quantities, so they do not change regardless of the volume (provided that the solution is uniform, or "well mixed"). So that 100 ml you remove will be 5% acetic acid, and the 400 ml left will be 5% acetic acid.
Think about it this way: if I tell you that 50% of a country's population is female, and ask you what percentage of the population of a given city in that country is female, what would you answer?
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
