Sonic Antifouling for Marine Vessel
  • Thread starter Thread starter Cammeo
    Marine Vessel
Sonic antifouling technology utilizes sound waves to prevent marine growth on vessel hulls, enhancing performance and reducing maintenance. The process involves emitting ultrasonic frequencies that create an environment unsuitable for barnacles and algae to attach. Visual diagrams can effectively illustrate how these sound waves interact with water and inhibit fouling organisms. Users seek detailed explanations and visual aids to better understand the mechanics and benefits of this technology. Overall, sonic antifouling presents a promising solution for maintaining marine vessels.
Cammeo
Need help with understanding with visual diagram how sonic antifouling for marine vessels work.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
