- 30,614
- 7,552
Excel will do most things if I'm determined enough! Cheers.
Rap said:How about this:
A guitar string can be quite accurately thought of as vibrating at a number of distinct frequencies, each at possibly different amplitudes. The lowest frequency is called the fundamental frequenciy, and the higher frequencies are integer multiples of the fundamental frequency. These various frequencies that the string vibrates at are called harmonics, the first harmonic being the fundamental, the second harmonic being twice that, etc. If you pluck a string, all of its harmonics are excited, the lower harmonics being the strongest.
rbj said:that is not necessarily the case. if you pluck your guitar string in the very center of it, only the odd-numbered harmonics are excited. if you pluck the string while constraining the nodal point in the very center of the string, then only even-numbered harmonics will be excited. if you pluck the string while constraining the nodal point 1/3 of the string length from either side, only harmonics that are integer multiples of 3 will be excited.
