Optimizing Sound Transmission: Shed Placement Tips for Blocking Noisy Neighbors
  • Thread starter Thread starter mtworkowski@o
    Sound
To effectively block noise from a neighbor's hot tub, placing a shed closer to the sound source is generally more beneficial, as it can absorb and reflect sound before it reaches the house. However, sound reflection and diffraction must be considered, as they can still contribute to noise issues. Some participants suggest that adding natural barriers like hedges or trees may be more effective than a solid structure. Resonance and echoing are also discussed as potential contributors to the noise problem, with active noise cancellation mentioned as a possible solution. Overall, a combination of strategies may be necessary to address the noise effectively.
mtworkowski@o
I have a question about sound transmission through air. In blocking the sound with a structure is it better to put the structure next to the sound source or next to me?
I'd like to put up a shed to block the sound of my neighbor's hot tub. When it's running I can hear it in my house. Would the shed be more effective if it were closer to the hot tub or closer to my house? The hot tub is 20 ft from from the property line and my house is 15 ft from the property line. My wife thinks the shed should go near the house and I think it would work better closer to the source of sound. Where is best. Thanks
Hey.
Next to you, because as sound travels a distance it gets quieter because it will be absorbed by other objects in its path. By having it away from the source, you will have already diminished sound trying to get through your shed.
Thanks for the quick response Ed. However, I don't think I agree with your answer. Sound does not diminish because it gets absorbed by objects in its path. Objects reflect sound. Sound is diminished at the rate dictated by the inverse square law. A point source radiating into a solid angle. That shed should reflect and absorb the sound and only leave a diffused source. I'm sorry to disagree with you but don't you think this is rather a good exercise? Anybody want to chime in on this, I would be very glad to hear from you. Thanks Ed.
Your neighbor's hot tub must be a pretty cheap model. I have mine right next to the sliding glass door in our den. When that kicks on I can't hear a thing.
From an industrial standpoint, it is always better to attenuate a signal at the source since there are so many factors that can affect the sound in the far field. This isn't necessarily the case here, but I think I agree with you in that the shed should be closer to the source. However, understand that you will still get reflections and probably some diffraction from the source. My opinion would be to put up a hedge or trees in between. It would be much more effective than adding another solid surface to bounce sound off of. Or, if that's not feasible, is your neighbor a nice enough person that you could look at adding insulation and maybe some panels to his tube frame?
Fred,
Thank you for you rresponse. I'm starting to think that some pecentage of the problem is resonance in that area of my house. You triggered that line of thought when you mentioned the patio doors in your den. Glass has a very high resonant frequency, not to mention it's ability to reflect sound. My neighbors are just noisy people and they don't seem to be aware of that fact. I find this to be an interesting problem to solve and I'm sure it will require a combination of things. I even considere active noise cancellation because of the predictable wave form of the hot tube. Any more ideas very welcome. Thanks again Fred.
No problem.
In your case, I wouldn't necessarily say resonance as the main problem. I would say echoing or reflection are your big problems to contend with. I am not an acoustician, but I would think that most residential sound sources would not have enough energy to really induce a structure's resonant modes to an audible level.
A noisy neighbor is a tough nut to crack. I have the same issue with a family behind us. They simply don't realize that they are very loud. I have hinted to them but I admit I haven't come right out to ask them to quiet down which would probably solve 99% of the problem. It is an interesting problem. The active noise cancellation would be kinda cool if you could get it to work.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
