chroot said:
The fundamental frequency is always taken to be that with the largest amount of energy.
i beg to differ. not only is there the present issue of tones with missing fundamentals, it is
common to find "natural" (non-electronic) instruments where there is a resonant cavity or something that boosts the amplitude of the 2
nd or 3
rd harmonic to an amplitude higher than that of the 1
st. the human singing voice is an example and Tuvan throat singers can tune in on much higher harmonics.
the fundamental frequency of a tone is the reciprocal of the smallest possible period.
f_0 = \frac{1}{T}
where
x(t+T) = x(t) \quad \forall t
since 2
T, 3
T, 4
T can also substituted for
T and satisfy the definition of periodicity (in other words, a 256 Hz tone could also be called a 128 Hz or 64 Hz tone if no other restriction was made to the definition, so we do not spuriously pick a fundamental frequency of a tone that has
no odd-numbered harmonics at all), we pick the smallest possible positive value for
T as the period that is inverted to be the fundamental frequency.
of course, because of Fourier:
x(t) = \sum_{n=-\infty}^{+\infty} \ c_n \ e^{i 2 \pi n f_0 t}
where
c_n = f_0 \ \ \int_{t_0}^{t_0+T} \ x(t) \ e^{-i 2 \pi n f_0 t} \ dt
for any arbitrary
t0.
it cannot be true for that
all odd
n, that each
cn is zero. if that were the case, we made an "octave error" and incorrectly chosen 2
T as the period (or some other even multiple), instead of what we should have.
If an instrumental sound is said be 256 Hz, that's the frequency of the fundamental. By definition,
i agree with this statement, but for what you mean by "fundamental". what would you say is the fundamental if you heard an instrument (or a "tone", or if you don't like that semantic, a "waveform") that had nothing at 256 Hz, but had energy at 512 Hz, 768 Hz, 1024 Hz, 1280 Hz, and maybe some more multiples of 256 Hz? perhaps that "instrument" is electronic (but it wouldn't necessarily have to be, you should check out the waveforms that come out of a Wurlitzer Model 200 electric piano from the '70s) and the tone is synthesized, but it's still an "instrument" in my semantic.
you would not call a sound with no energy at 256 Hz a "256 Hz tone."
yes, i would, if it had 512 Hz, 768 Hz, 1024 Hz, etc. even if there was no energy at 256 Hz.
Sure, the trumpet is capable of higher notes which cannot be played on the trombone, but that certainly does not mean that any arbitrary trumpet will always be able to play higher notes than a better-skilled trombone player.
didn't mean to imply differently. only to say that
normally, however we can define "normally" (i didn't say "generally" which is what the OP said), you
normally measure the trumpet to be outputting higher frequencies than the trombone. the "spectral centroid" would normally be higher for the trumpet than the trombone.
