Sound Waves-Destructive Interference hw help please
  • Thread starter Thread starter reality99
    Interference Sound
The discussion revolves around a homework problem involving two loudspeakers and the conditions for destructive interference. The speakers are positioned 5 meters apart vertically, with a detector 12 meters away horizontally and 3.2 meters above the lower speaker. The goal is to determine how far the top speaker must be moved to achieve destructive interference, given that the current setup results in constructive interference. Participants suggest starting with the principles of constructive and destructive interference to derive the necessary equations. The original poster seeks guidance on how to derive the final equation provided.
reality99
Two loudspeakers are placed a distance of 5m above and below one another and driven by the same source. A detector is positioned a perpendicular distance of 12m from the two speakers and a vertical height 3.2m from the lower speaker. This results in constructive interference at the first order maximum. What minimum distance (in any direction0 should the top speaker be moved in order to create destructive interference between the two speakers?
*Velocity of sound=345m/s
This is what the final equation comes out to be, I just don't know how to derive it.
distance apart=dA
detector placement distance=dD
detector vertical height=dH
((SQRT(dD^2+((dH-dA/2)+dA/2)^2)-(SQRT(dD^2+((dH-dA/2)-dA/2)^2)/2)
I honestly have no clue how to do this or even where to start. I know the final equation and the answer, just not how to get to it. Any help is appreciated. (equation is above)
Welcome to PF.
I'd start with the conditions for constructive and destructive interference to happen.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
