Source transformations doesn't always produce same result?
Source transformations can change circuit behavior, particularly in RC circuits. In a series RC circuit with a DC voltage source, once the capacitor is fully charged, all voltage is across the capacitor and no current flows. However, when transforming to a parallel RC circuit with a DC current source, current continues to flow through the resistor, resulting in voltage across both components. The final voltage across the parallel setup is determined by the current times the resistance, confirming the voltage would be 30 V in the given example. Understanding these nuances is crucial for accurate circuit analysis.
eng_stud
I was under the impression that a source transformation doesn't change a circuit at all, which I guess is an oversimplification.
If you have a series RC circuit, with a DC voltage source, after the transients have died out, all voltage will be across the capacitor, and none across the resistor, as there is no current flowing anymore (when cap is fully "charged"), right?
If you now do a source transformation, changing the DC voltage source to a DC current source, with the resistor in parallel, you now have a parallel RC circuit with a DC current source. Now, surely, current will never cease as it has another path through the resistor. So after the capacitor is charged, all current goes through the resistor. So in this case there's voltage across both the resistor and capacitor?
This might all be incredibly obvious. I just want to make sure there is nothing here that I have misunderstood!:)
Follow-up question: If you have a circuit with a 10 A dc current source, with a 3 Ohm resistor and a 0.02 F capacitor in parallel, what determines the resulting voltage across the parallel setup? When the capacitor is fully charged? Or the voltage that would have been the source had we done a source transformation? (i.e. v=ir=10*3=30 V across both components).
I'm assuming the latter?
Your understanding in both posts is correct. With a current source, a resistor and capacitor in parallel the final source voltage will be equal to the current times the resistance.
Thanks, skeptic2!
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
