- 37,494
- 14,383
A mostly successful launch of Ariane 6. It reached its nominal orbit and deployed various cubesats. A maneuver two hours after launch didn't work as expected, leaving two reentry test capsules in a wrong (non-reentering) orbit.
Scientists have for the first time discovered a cave on the Moon.
At least 100m deep, it could be an ideal place for humans to build a permanent base
The cave has a skylight on the Moon’s surface, leading down to vertical and overhanging walls, and a sloping floor that might extend further underground.
It was made millions or billions of years ago when lava flowed on the Moon, creating a tunnel through the rock.
As expected: SpaceX requests public safety determination for early return to flight for its Falcon 9 rocketmfb said:SpaceX will push for a separate and faster conclusion that there is no risk for the public (to launch again) and a full accident investigation that can take more time.
If the FAA agrees with SpaceX’s determination, the Falcon 9 could resuming launching. The company has tentative plans to launch both the Starlink 10-4 and Starlink 10-9 missions from its two launchpads in Florida later this week. This would be pending the approval of the FAA, of course.
One informed source said it was greater than a 50-50 chance that the crew would come back on Dragon. Another source said it was significantly more likely than not they would. To be clear, NASA has not made a final decision. This probably will not happen until at least next week. It is likely that Jim Free, NASA's associate administrator, will make the call.
Yes, this is the same Starliner program that undocked autonomously before. It's the same capsule that flew the first uncrewed flight test - didn't reach the ISS, but it certainly had the software to undock from it!Three separate, well-placed sources have confirmed to Ars that the current flight software on board Starliner cannot perform an automated undocking from the space station and entry into Earth’s atmosphere.
sources described the process to update the software on Starliner as "non-trivial" and "significant," and that it could take up to four weeks.
Since July 27, Falcon 9 has flown 6 missions already.mfb said:NASA will ask for a few missions with the new configuration before Crew-9, but SpaceX should reach these quickly.
Yikes. Sounds like we need a cowboy space plan, with an EVA after one of the astronauts undocks the craft from inside, points it down and boogies out the hatch...mfb said:What made Boeing remove that functionality? And why does it sound like they only start working on that now? Certainly this has been a high priority item since Starliner showed more issues in space?
You have got to be kidding.mfb said:The Starliner saga continues. NASA likely to significantly delay the launch of Crew 9 due to Starliner issues
The ISS only has two docking ports shared between Dragon and Starliner. Currently both are used for Crew-8 and Starliner's crewed flight test. NASA strongly prefers launching the next crew (i.e. Crew-9) before returning the previous one, but that only works if Starliner leaves.
CAPE CANAVERAL, Fla. (AP) — What should have been a quick trip to the International Space Station may turn into an eight-month stay for two NASA astronauts if they have to switch from Boeing to SpaceX for a ride home.
There’s lingering uncertainty over the safety of Boeing’s new Starliner capsule, NASA officials said Wednesday, and the space agency is split over the risk. As a result, chances are increasing that test pilots Butch Wilmore and Suni Williams may have to watch from the space station as their Starliner is cut loose to return to Earth empty.
If that happens, NASA would leave behind two of four astronauts from the next SpaceX taxi flight in late September, with the vacant seats set aside for Wilmore and Williams on the return trip next February. The pair expected to be gone just a week or two when they launched June 5 as Starliner’s first crew.
Boeing? Ignoring proper testing and safety procedures? Noooo, perish the thought.Filip Larsen said:More clarifying details from NASA on the latest development (or lack thereof) regarding Starliner docked at ISS:
https://arstechnica.com/space/2024/...l-disagreement-on-safety-of-starliner-return/
Since the issue with the thruster oxidizer valve now seem to have been reproduced on ground it is puzzling to me why this issue was not discovered in all the testing that went before a crewed launch. Clearly, something should have been done differently during testing.
Impossible! A new report finds Boeing’s rockets are built with an unqualified work force.Flyboy said:Boeing? Ignoring proper testing and safety procedures? Noooo, perish the thought.![]()
Guess they didn't expect people to actually ask for that capability?Just because the Starliner can fly to and from the International Space Station without human intervention does not mean humans can’t take charge.
One of China’s Long March 6A rockets has broken apart in low-Earth orbit and created a debris cloud consisting of hundreds of pieces, according to multiple space debris-tracking entities.
The rocket launched from the Taiyuan Satellite Launch Center on Tuesday to deliver 18 G60 satellites into orbit, which marks just the first deployment for the Shanghai Spacecom Satellite Technology group’s Thousand Sails constellation.
Shanghai Spacecom Satellite Technology did not respond to CNN’s request for comment. US Space Command, a branch of the US Department of Defense, confirmed the breakup of the rocket on Thursday.
While NASA requires its aerospace contractors to have quality assurance programs that comply with SAE International’s AS9100D standards on quality management systems, we found Boeing’s quality management system at Michoud does not adhere to these standards or NASA requirements. NASA engages DCMA to conduct surveillance of Boeing’s core and upper stage manufacturing efforts at Michoud, and when deficiencies in quality are found, DCMA issues Corrective Action Requests (CAR) to the contractor. CARs are labeled Level I through IV, with Level I the least serious deficiency.
From September 2021 to September 2023, DCMA issued Boeing 71 Level I and II CARs, as well as a draft Level III CAR.According to DCMA officials, this is a high number of CARs for a space flight system at this stage in development and reflects a recurring and degraded state of product quality control. Boeing’s process to address deficiencies to date has been ineffective, and the company has generally been nonresponsive in taking corrective actions when the same quality control issues reoccur.
From 2019 - https://oig.nasa.gov/wp-content/uploads/2024/02/IG-20-005.pdfOngoing issues with Boeing’s Starliner spaceship have been front and center this summer, but a new government report highlights other shortcomings of the company's aerospace work.
The report, released Thursday by NASA’s Office of Inspector General, calls into question Boeing’s standards and quality control for its part in NASA’s efforts to return astronauts to the moon.
In NASA's development of its next-generation megarocket, known as the Space Launch System, it gave Boeing the contract to build the rocket system’s powerful upper stage.
But according to the report, Boeing’s quality control systems fall short of NASA’s requirements, and some known deficiencies have gone unaddressed. What's more, the workers on the project are not, as a whole, sufficiently experienced or well trained, according to the inspector general.
