Space Travel: SR Questions Explored
PerenialQuest
Hello All,
I'm trying to wrap my head around SR and I have a couple questions: If two space travelers (A) and (C) take off from a Planet (B) in opposite directions and each travels just over 1/2c, do they vanish from each others' view? I don't see why they wouldn't but
If yes, doesn't that violate SR which nothing can travel at v > c? Since they don't observe each other is that avoided?
Also does that mean that no information can ever travel from (A) to (C)? If yes, couldn't (B) just act as a medium of communication which is moving at < c in relation to both (A) and (C).
Also, let's say (A) and (C) turn around and travel back toward each other with a combined v > c, what would this look like to each space traveler?
Thanks for your time,
Rich
huh! it really is! that's wild! thanks
Ok but Lawrence Krauss told me that because of Dark Energy, all the galaxies will eventually be traveling at > c with relation to each other and will disappear from each others' view. He also said that this doesn't violation SR. Explain that!
SR doesn't apply to cosmology. In GR, the relative velocity of cosmologically distant objects is not uniquely well defined. It's only locally that relative velocities are well defined and have to be <c.
The interpretation of cosmological horizons that you're quoting is an oversimplification: Davis and Lineweaver, Publications of the Astronomical Society of Australia, 21 (2004) 97, msowww.anu.edu.au/~charley/papers/DavisLineweaver04.pdf
ok thanks!
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
