Spacecraft Acceleration Question
The discussion revolves around calculating the x and y components of acceleration for a spacecraft with given initial velocities and displacements. The user attempts to apply the equation D = Vo*t + 1/2 at^2 but misinterprets the results, mistakenly equating displacement with acceleration. Clarification is provided that the equation should be solved for acceleration "a" directly, rather than deriving incorrect values. Additionally, there is a note on the need for consistent units in the calculations. The correct acceleration components are ultimately identified as 17.6 m/s² for x and 25.9 m/s² for y.
Lokhtar
On a spacecraft , two engines are turned on for 684s at a moment when the velocity of the craft has x and y components of Vox=4370 m/s and Voy = 6280 m/s. When the engines are firing, the craft undergoes a displacement that has components of x= 4.11x10^6m and y = 6.07x10^6m. Find the x and y components of the craft's acceleration.
D = Vo*t + 1/2 at^2
For X:
4.11*10^6m = 4370m(684s) + 1/2 a(684s)^2 = 4.79m/s^2
For Y:
6.07*10^6m = 6280m(684s) + 1/2 a(684s)^2 = 7.56m/s^2
The answers given are 17.6m/s^2 and 25.9m/s^2, but I am not sure why. I'd appreciate any help.
Lokhtar said:
For X:
What is this "= 4.79m/s^2" all about? You're saying that
4.11*10^6m = 4.79m/s^2
which is false. The units don't even match.
Just solve the equation for "a". (And forget the 4.79m/s^2 part).
p.s. you probably know this, but the 4370m should have different units.
