Spacetime, curvature, orbit, matter and reactions
Elliot.exe
In the BBC film Einstein and Eddington, Eddington describes the theory of spacetime using a table cloth (space), a loaf of bread (sun) and a piece of fruit (a planet).
The Bread is placed in the middle of the table cloth, this forms curves in the cloth. He then takes a piece of fruit and throws it in. The fruit oribits the bread along the curves. This shows spacetime.
This provoked and idea in my head, The sun is a source of light, In the curves of the cloth there are shadows caused by the sun. The curves of space might have light from the sun causing a "shadow" of light particles or matter in the same way there was a shadow in the cloth. I also think this might cause a reaction as a planet orbits. the idea is rough but in theory it could work.
Or is it all just, like Thunderbirds just string theory
Elliot.exe
Well, I wouldn't take the table cloth analogy too seriously (it has big flaws) but you can get gravitational lensing, so I would think you could get other optical effects like shadows.
No this is not spacetime. This is just space (2 dimensions of it). There is no time dimension in this analogy which is crucial for the gravity model of General Relativity. Follow the links in this post, for better visualizations:
https://www.physicsforums.com/showthread.php?p=2046692
You are completely misunderstanding the analogy here. The cloth itself represents the space in which light is propagating. So in this analogy the light from the bread (sun) would propagate only within the cloth, not outside of it. There are no shadows caused by spatial curvature around the sun, but optical distortions are possible as DaleSpam said.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
