Proving Graph Theory Theorem: T and T' Spanning Trees of G
  • Thread starter Thread starter tiagobt
    Tree
The discussion centers around proving a theorem in graph theory regarding spanning trees T and T' of a connected graph G. The theorem states that if edge x is in T but not in T', and edge y is in T' but not in T, then both (T - {x}) U {y} and (T' - {y}) U {x} must be spanning trees of G. The original poster, Tiago, initially misinterpreted the theorem but later clarified that the existence of y depends on the choice of x. Suggestions were made on how to approach the proof, emphasizing the need to avoid creating cycles while ensuring all vertices remain connected. Ultimately, the discussion highlights the complexity of proving the theorem while ensuring the properties of spanning trees are maintained.
tiagobt
I'm trying to prove the following theorem using graph theory:
T and T' are two spanning trees of the connected graph G. If x is an edge that belongs to T, but not to T' and y is an edge that belongs to T', but not T, then:
(T - {x}) U {y}
and
(T' - {y}) U {x}
are spanning trees of G.
I first tried to come up with an example:
Graph G
Vertices: a, b, c, d.
Edges: ab, ac, ad, bc, cd.
Spanning tree T
Edges: ab, ac, ad. (x = ac)
Spanning tree T'
Edges: ad, cd, bc. (y = bc)
Spanning tree (T - {x}) U {y}
Edges: [(ab, ac, ad) - (ac)] U bc = ab, ad, bc.
Which is really a spanning tree.
Spanning tree (T' - {y}) U {x}
Edges: [(ad, cd, bc) - bc] U ac = ad, cd, ac.
But this is a cycle that leaves b apart, not a spanning tree!
What did I do wrong?
Thanks,
Tiago
Mathematics news on Phys.org
are you sure the question says prove: or is it prove/disprove?
If I recall correctly the theorem should be that given an x in the edge set of T but not in the edge set of T' then there exists a y in the edge set of T' that is not in the edge set of T such that ... (same conclusion)
so the y depends on x
Though I haven't looked this up... this is just my vague recollection
Yes, I'm sure. The question asks me to prove the theorem.
I guess you're right: the theorem also says that, if there is an edge x in T, but not in T', then there is an edge y which is in T', but not in T. But I guess my first example follows this as well: x = ac is an edge that belongs to T, but not to T'; then there must be an edge y that belongs to T', but not to T. In my example, y = bc. Am I missing anything?
OK, I guess I figured it out. I misunderstood the theorem. I'll try to restate it:
T and T' are two spanning trees of a connected graph G. Suppose that x is an edge in T, but not in T'; then there is an edge y in T', but not in T, so that
(T - {x}) U {y}
and
(T - {y}) U {x}
What I understand is that, if there is x, then there must be at least one y that follows the theorem. In other words, not every edge that belongs to T' but not to T is the y that the theorem wants. In my example, bc is not good to be y. I could, however, choose x = ac and y = ad, finding the following spanning trees:
- ab, ad, bc
- ac, bc, dc
Is this right?
I believe that's the right idea. Of course proving it is a bit more of a challenge.
suggestion
I don't know if this will work, but could you do something like this:
Given spanning trees T and T', take an edge, x, in T that connects U to V that is not in T'.
Since x was the bridge from U to V, to re-create a tree, we have to replace it.
In T' there was also a U-V path, because in trees all vertices have to be connected, but we can also not duplicate any other path in the tree or create a circuit because the end result also has to be a tree...
So the problem lies in re-building that bridge.
What I am thinking is, can you say that you'll add the path without duplicating it because T and T' are not the same tree?
We did have that to begin with? Or not?
I'm not sure if maybe you could say use an algorithm to create a tree but avoid using that initial branch?
Another thing I'm thinking is maybe you could say that if you add the edge from the other tree, you will create a circuit so there are 2 paths from U to V, then break the circuit by taking out the original x from T and you will still have a tree.
I don't know if either of these approaches will work for you, tell me what you think.
- Vanes.
ah for the restated question it is a simple PROOF (10-15min)
the question is about disconnected graphs and parity.
[1]T -{x} = ?
[2]T'+{x} = ?
Apply parity of [1] on what you can think of for [2]
EASY AS PIE
