Time Dilation: Inside a Rotating Sphere of Light
  • Thread starter Thread starter vikram chawan
    Relativity
vikram chawan
please can u resolve my doubt regarding this ..."What if i fixed a chair inside a sphere and i am sitting on it and it is not rotating whereas the sphere is rotating with the speed of light ?" "Will time be different for me inside the sphere and for the people outside?"
But what if i am rotating with the speed of light with the sphere?will the time be different then??
... taking "rotating at the speed of light" to mean "rotating with a speed very close to the speed of light": I agree with russ_watters.
realize you cannot rotate at the speed of light, since you have mass.
Further, when you talk about speed, it is important to say what the speed is relative to.
In the first case we can talk about the speed of the sphere relative to the chair, since you specified that it was stationary.
In the second case, you are spinning in the frame of reference of "everyone else" (i.e. outside the sphere), and we assume that "everyone else" are inertial observers.
You should be able to do the math for that.
There is no such thing as "rotating with the speed of light". The speed of light is a linear speed, not a rotational rate (and yes, as Simon says, you can't reach the speed of light, just something close to it...if you have the right apparatus). However, if you were to spin at a high rate (without disintegrating), different parts would experience different time dilation based on the particular linear velocity they had. We have clocks that are accurate enough they could be mounted on/next to a centrifuge to measure that.
Thank you so much for the answers...
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
