Special Relativity and Kinematics Problem
The problem involves three particles A, B, and C moving along the x-axis, with A traveling at 4/5c and B at 3/5c, while the speed of C is unknown. The goal is to determine the speed of C so that A and B arrive at C simultaneously, with both A and B approaching C at 5/13c. The discussion highlights the use of time dilation and relative speed equations from special relativity to analyze the scenario. A suggestion is made to simplify the problem by treating it as a kinematics issue, focusing on the distances and the time it takes for A and B to meet. This approach allows for a clearer calculation of C's speed without heavily relying on relativity concepts.
ToothandnaiL
There are three particles along the x-axis ordered from back to front, A, C, B. A travels at 4/5c and B travels at 3/5c, the speed of particle C is unknown. What must the speed of particle C be such that A and B will arrive at C at the same time? And, at what speed will both the particles approach C?
(1) Δ(t)= ([Δ(t)]'/[1- (v^2/c^2)])^(1/2) (for time dilation in each reference frame)
>> \gamma= [1- (v^2/c^2)])^(1/2)
(2) u'=[(u-v)/(1- [uv/(c^2)]) (for speeds of particles relative to each other, u' is the modified speed of a relative moving object after special relativity is taken into account, u is the speed presented in the problem without reference to any other moving object or frame)
These are the two equations I have used to attempt this problem.
I calculate the speed of particles A and B relative to each other using eq. 2. I split the problem into a reference frame for the A and B particles and a frame for the C particle. I use eq. 1 to account for time dilation and in turn speed differences among the particles. I think I have correctly calculated the speed of A and B to be approaching each other at 5/13 the speed of light. Other than that I have failed multiple times in trying to get the speed of C.
I've even gone as far as to assign a random length to the configuration of particles in order to have some concrete values to work with, although this shouldn't be necessary. If I know that both A and B are approaching C at 5/13c then I know there is a way to figure the speed of C. I think there is a kinematic aspect that I'm overlooking here. Any and all suggestions are welcome and thanked in advance.
Are they all moving in the same direction? What are the initial locations of A, B, and C? Where do A and B meet? (All this can be done from the frame in which A, B, and C are moving at the given speeds.)
All the particles are moving in the positive x direction. C is in between A and B, with behind and B in front. A and B will arrive at C's position simultaneously.
How far apart are they when they start out?
A and B are equidistant from C, sorry I forgot to mention this in the previous post.
OK. To find the speed of C, here's what I would do. Just let L be the distance between A-C and C-B. Now just solve the kinematics problem of when will A overtake B? (Just solve it symbolically.) Then you can figure out the speed of C, since C has to meet B in that same time. This part has nothing really to do with relativity.
Ok, that makes the problem a lot more straight forward. Thanks for bearing with me and your insightful input.
