Special Relativity -- Dynamics -- Energy
14 replies · 3K views · last reply
Barry Melby
Antihydrogen is the only antimatter element that has been produced in the laboratory, albeit just a few atoms at a time. Each antihydrogen atom consists of a positron in orbit around an antiproton and has the same atomic mass as hydrogen. If an antihydrogen atom collides with a hydrogen atom, they annihilate each other and create gamma radiation.
If this energy could be harnessed in a matter-antimatter automobile engine, how far could a car travel on 10 mg each of antihydrogen and hydrogen? At highway speeds, a typical automobile expends about 2.5×10^3 J per meter.
E = mc^2
I know the answer is 9.00 * 10^8 m, but I haven't been able to work out an answer that is even close to this.
I've solved the minimum amount of energy that is released in this process (3.01 * 10^-10 J). I'm not sure if this is relevant, but I solved it if necessary.
Hi Barry:
I think you omitted an important equation: E = mc2.
Hope this helps.
Regards,
Buzz
Okay, so if i use E = mc^2 with m = 10 mg then i get 9 * 10^12 J. Where do I go from here?
Hi Barry:
Look at the end of 1. Problem Statement. Also be careful about your units.
Regards,
Buzz
I realize that you should be able to take E / 2.5 * 10^3 J/m , but this is incorrect.
Hi Barry:
What units are you using for c and m?
Regards,
Buzz
Hi Barry:
What values are you using for c and m?
Regards,
Buzz
Buzz Bloom said:
Hi Barry:
Regards,
Buzz
c: 3.00 * 10^8 m/s
m: 10 * 10^-5 kg
Hi Barry:
How are you converting 10 mg into kgs?
Regards,
Buzz
Hi Barry:
Also, what is the TOTAL input mass, hydrogen and anti-hydrogen?
Regards,
Buzz
Buzz Bloom said:
Hi Barry:
Regards,
Buzz
This is exactly what I'm doing:
[(20 * 10^-6)(3 * 10^8)^2] / (2.5 * 10^3) = 720000000
which is incorrect.
Hi Barry:
OK. You get the same answer I do, which is not the same as the answer you say you know is correct: 9.00 * 10^8 m. Where did this "correct" answer come from?
Regards,
Buzz
Barry Melby said:
i figured it out. thank you.
Hi Barry:
Glad to have been of some help.
Regards,
Buzz
