Special relativity: find speed and kinetic energy
The discussion focuses on calculating the kinetic energy, momentum, and speed of a proton with a rest mass of 1.67x10^-27 kg and total energy 3.2 times its rest energy. The relevant equations include E(0) = m(0)c^2 for rest energy, E = mc^2 for total energy, and the relativistic kinetic energy formula Ke = (\gamma - 1)m(0)c^2. The user correctly calculates the rest energy and total energy but struggles with deriving the correct kinetic energy and speed using the momentum equation p = mv and the gamma factor. The correct approach involves using the gamma factor, which is determined from the total energy equation.
  • Understanding of special relativity concepts, including rest mass and relativistic mass.
  • Familiarity with the equations for energy and momentum in relativistic physics.
  • Knowledge of the speed of light (c) and its significance in relativistic calculations.
  • Ability to manipulate algebraic equations to solve for unknown variables.
  • Learn how to calculate the gamma factor (\gamma) in relativistic physics.
  • Study the derivation and application of the relativistic kinetic energy formula.
  • Explore the relationship between momentum and velocity in relativistic contexts.
  • Practice solving problems involving total energy and rest energy in special relativity.
Students studying physics, particularly those focusing on special relativity, as well as educators and tutors looking to clarify concepts related to relativistic energy and momentum calculations.
k77i
A proton (rest mass 1.67x10^-27 kg) has total energy that is 3.2 times its rest energy. What is:
a) the kinetic energy of the proton (in joules)
b) the magnitude of the momentum of the proton (in kg*m/s)
c) the speed of the proton (in terms of the speed of light "c")
E(0) = m(0)c^2
where E(0) is rest energy, m(0) is rest mass and c is the speed of light (approximately 3.00x10^8 m/s)
E = mc^2
where E is the total energy (im not too sure if that's the formula for total energy) and m is the relativistic mass
p=mv
where p is the momentum
E^2 = (p^2)(c^2) + (m(0)^2)(c^2)
Ke = E - m(0)c^2
where Ke is the kinetic energy
I found the rest energy E(0) = m(0)c^2 = 1.503x10^-10 and since my total energy = 3.2 times the rest energy, E = 3.2E(0) = 4.81x10^-10.
And because E = mc^2, i can use the previously calculated value to find m which gave me m= 5.344x10^-27.
I used these values and the equation E^2 = (p^2)(c^2) + (m(0)^2)(c^2)to find the momentum which gave me 1.603x10^-18, which is correct.
But when i use the formula p = mv and rearrange it as v = p/m, i get 0.9999c m/s which according to my homework isn't correct.
And also, when i use the equation Ke = E - m(0)c^2 to find the kinetic energy, i get 3.307x10^-10, which is also incorrect.
I know it's long but a little help would be appreciated.
Relativistic momentum is p=\gamma m_0v and relativistic kinetic energy is (\gamma -1)m_0c^2 with \gamma=\frac{1}{\sqrt{1-\frac{v^2}{c^2}}}
See if you get the right result with these expressions.
but how would i calculate the gamma value if i don't have the velocity?
Total energy is E=\gamma m_0c^2 and rest energy is E_0=m_0c^2. Now take another look at the problem statement. Can you figure out what the velocity and the value of gamma is?
Ok then suppose that before i look for the velocity, i want to find the kinetic energy first. If i use the equations E= (gamma)m(0)c^2 and E(0) = m(0)c^2 , i can find the value for gamma, which gives me 3.2. if i then use the equation (gamma -1)m(0)c^2 to find the kinetic erergy it gives me 3.307x10^-10. Why is this answer wrong?
  • · Replies 54 ·
11K
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 58 ·
