Special Relativity -- Kinetic Energy
The discussion revolves around a problem in special relativity involving the collision of an electron and a positron to produce a proton and an antiproton. Participants are tasked with calculating the minimum ratio of the electron's kinetic energy to its internal energy necessary for the reaction to occur, considering the mass relationships between the particles involved.
  • Participants express uncertainty about the problem's requirements and seek guidance on how to approach the calculation of the energy ratio. There are discussions about the significance of the minimum energy needed for the reaction and the implications of the rest mass energy of the produced particles.
Some participants have identified relevant equations and concepts, while others are exploring the implications of the particles' rest mass energies. There is an ongoing dialogue about the role of momentum and total energy in the context of the reaction, with hints towards conservation principles being discussed.
Participants are navigating the complexities of relativistic energy and mass relationships, with specific attention to the conditions required for the reaction to take place. The discussion reflects a lack of consensus on the interpretation of the energy calculations and the implications of the particles' velocities post-collision.
Barry Melby
An electron e− and positron e+ moving at the same speed in the Earth reference frame collide head-on and produce a proton p and an antiproton p¯. The electron and positron have the same mass. The proton and antiproton also have the same mass. The mass of the proton is 1836.15 times the mass of the electron.
Calculate, in the Earth reference frame, the minimum value possible for the ratio of the electron's kinetic energy to its internal energy in order to have the reaction e− + e+ →p + p¯ take place.
Want: K/E_internal = ?
K = (y-1)mc^2 --- y = lorentz factor
E_internal = mc^2
I'm not even remotely sure what this question is asking. Can someone offer me some guidance?
E_internal = mc^2
You have the correct equations, so you need to figure out the ratio which is simply ##\gamma-1##.
To find that, the key point is that you want the minimum energies for the e+ and e- to have the reaction take place. This is a special case. What can you say about the proton and antiproton produced then?
Well i know that the mass of the proton and the antiproton are 1836.15 times the mass of the electron and positron. Would ##\gamma## = 1/(1-1836.15^2)?
No no, never mind. That wouldn't make sense.
Where do i go?
Where do i go?
As I mentioned earlier, the key point is that you want the *minimum* energy for the e+ and e- to have the reaction take place. This is a special case. What can you say about the proton and antiproton produced then?
I don't really understand what you're saying.
Do i have to do something with momentum?
In a general problem, you would have to apply conservation of momentum. Here, you are luckier because that won't be necessary. What is the speed of the proton and antiproton produced, in your question?
it doesn't appear that the proton or antiproton are moving at all.
Exactly! Now, what is the total energy of the system after the reaction?
The total energy would be zero i would suspect because they have no velocity. How does this relate to ##\gamma##?
Not quite. The total energy is not just kinetic energy, in relativity. It includes rest mass energy. So what is the total energy, taking this into account? (Once you find that, you can write an expression for the total energy before. Using conservation of total energy, you will get an equation for gamma that you can then solve for.
##E = M c^2 = 0## only if ##M = 0##.
  • · Replies 31 ·
  • · Replies 21 ·
13K
