Chemistry Specific Rotation of Chiral Molecules
The specific rotation of (R)-(+)-limonene may be lower than the literature value due to the presence of achiral methylene chloride in the sample, which can dilute the optical activity. Although methylene chloride itself does not rotate plane-polarized light, its presence can affect the overall concentration of the chiral compound in the solution. The calculation of specific rotation requires knowing the observed rotation and the concentration of the chiral substance, which can be influenced by the solvent used. Ethanol, as the solvent, is not expected to affect the optical activity of limonene, but the dilution effect from methylene chloride could lead to a lower observed specific rotation. Understanding these interactions is crucial for accurate determination of specific rotation in chiral compounds.
Cyberchicken
Why may the specific rotation of a sample of (R)-(+)-limonene be less than the literature value of (R)-(+)-limonene. Assume that there are so (S) enantiomers present.
There are no (S) enantiomers, but there are some molecules of methylene chloride mixed into the sample that was analyzed. But since these are achiral, I don't understand why they should affect the rotation of the limonene.
When you calculate the specific rotation of a sample, what values do you need to know? Would the presence of solvent affect any of those values?
The solvent used was ethanol, so that should not affect the optical activity. Are there any other factors which would affect it? Like the presence of methylene chloride perhaps? And why would it affect it?
Again, think about how you calculate the specific rotation of a sample. You place your sample in the polarimerter and obtain the angle by which your sample rotated the light. How do you calculate the specific rotation from that value?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
15K
16K
