Spectral width of an optical pulse
Pulsing a continuous wave (CW) laser can affect its spectral content, particularly through methods like Q-switching, which uses an optical shutter to create short pulses. This technique results in a Gaussian spectral profile that widens as pulse duration decreases, without introducing linear chirp. Alternatively, pulsing the drive current of a diode laser can also control pulse length, but it raises questions about its impact on spectral width and whether it results in a transform-limited pulse. The relationship between pulse width and spectral width is governed by Fourier transforms, indicating that shorter pulses yield broader spectra. Understanding these dynamics is crucial for effective laser design and application.
narra
If we take a CW laser,say, and operate a pulsed regime, will this directly effect the spectral content of the emitted light?
Is there anyway that we can pulse this laser without introducing linear chirp?
Thank you
Science news on Phys.org
Thank you
It's a bit of a pain to retrofit pulsing to a cw laser better to design it in. One option has been used for a long time - Q switching. You put a fast optical shutter (Kerr cells are often used) in the beam path between the mirrors. You pump the laser medium to get a population inverse and then 'open' and 'close' the shutter to generate a pulse of the required duration. Pitfalls to avoid - the power ofthe pulse will be many times the cw power of the laser so cooling may be required to stop the laser medium cooking. Also keep the pulse short enough that you still have a population inverse at the end of the pulse (just) or you will mess up the wave the wave train and hence the spectrum.
Speaking of spectral width if you Q switch the power / frequency curve will be a gaussian (bell curve). It will get get wider the SHORTER the pulse width (direct consequence of Fourier transforms) but in no way will it chirp. The rule is shorter the pulse the wider the spread of the spectrum.
Another way to pulse a laser is mode locking but this is more complex to do and the spectral signature is more complex.
Hope this helps
Thanks Sam, this was a very interesting reply and I am tempted to ask further questions relating to it. But at the moment, at least, can I ask what if Q-switching wasn't a reasonable solution. Let's say we had I diode laser which we wanted to pulse. Pulsing the drive current seems like an easy first approach because all we need is a waveform generator (talking simplistically). We could then control our pulse length with ease by varying the drive current profile.
If this was the case, I am a little bit unsure of what's happening to the pulse: are we changing the pulse width and thus directly changing the spectral width (as in a Fourier relationship)? Or are we just making the pulse less transform limited?
Also, is a pulse that is emitted without chirp effectively the exact same thing as a transform-limited pulse, assuming this pulse has not yet undergone any broadening?
Thank you
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
