Speed of a plane given distance and time equation.
  • Thread starter Thread starter brandy
    Plane Speed Time
To determine the speed of an aircraft flying at 10,000 m altitude with an increasing angle of elevation of 60 degrees at a rate of 1 degree per second, the correct approach involves using the formula 10,000/(Tan(a+x))=m, where 'a' is the angle and 'x' is time in seconds. The discussion highlights confusion regarding the application of the average velocity formula and the need for proper notation in the equations. A suggested correction involves calculating the change in horizontal distance (∆x) using the derivative of the tangent function with respect to time. The conversation emphasizes the importance of clarity in mathematical notation to avoid errors. Ultimately, the solution requires careful application of trigonometric principles to find the aircraft's speed in meters per second.
brandy
an aircraft at an altitude of 10 000 m is flying at a constant speed on a line that will take it directly over an observer on the ground. if the observer notes that the angle of elevation o the aircraft is 60 degrees and is increasing at a rate of 1 degree per second find the speed of the plane in metres per second.
i got the formula for the equation as 10 000/(Tan (a+x))=m
a=angle x=seconds m=metres across.
i can't think why it would be incorrect. the velocity is metres per second so delta M over Delta T or Delta y over Delta x (the gradient function)
that didnt get me anywhere because i didnt know wat to sub in for the equation
then i simply took an m value and a x value and used the average velocity formula but as expected it changed.
plllllllllleeeassse i know the answer is staring me right in the face, I am just temporaily blind. help me.
Hi brandy! :smile:
(have a delta: ∆ :wink:)
hmm … your notation is horrible, and you've left out half of the rhs :frown:
you should have ∆x = v ∆t = 10 000/(Tan (60º + ∆t)) - 10 000/(Tan (60º)) :smile:
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
