So, V_F= 11m/sWhat is the speed of the potted plant after falling 6m?
  • Thread starter Thread starter mcHefner
    Plant Speed
The discussion centers on calculating the final speed of a potted plant after falling 6 meters from a 12-meter high ledge. Participants agree that mass is irrelevant in this scenario due to the conservation of mechanical energy. Using the equation v² = 2gh, the first participant calculates a final speed of approximately 11 m/s. Another participant arrives at a slightly lower speed of about 10.84 m/s using a different method involving initial velocity and acceleration. Both calculations confirm the principles of energy conservation in free fall.
mcHefner
[PLAIN]http://img8.imageshack.us/img8/664/photo4dc.jpg
Sorry it is sideways.
Only known data is the 6m drop from the 12m high ledge.
Currently wokring with Kinetic energy (1/2mv^2), potential energy(mgh).
My thinking is mass doesn't matter, it will cancel out due to the mechanical energy( if that makes sense). Therefore the equation to solve is v2f=2gh
Therefore after subbing in 9.81m/ss for g, 6m for h; my final answer is 11m/s with rounding because of sig figs.
Thank you for help
Uh, do you think you could make that figure a little bigger ... I mean, I can almost see 25% of it at a time as it is.
I also got 11m/s, but found that answer in a less complicated way:
You know:
velocity_initial is 0m/s
Distance is 6m
Acceleration is 9.8m/ss
So:
velocity_final= SQRT(2*A*D)
V_F= SQRT(2*9.8*6)
V_F= 10.844m/s
