Speed of a Proton in an Electric Field
The discussion focuses on calculating the final speed of a proton in a uniform electric field of 2.41E+3 N/C after moving a distance of 1.85 mm. Participants emphasized using Newton's second law (F=ma) to determine acceleration, which was calculated to be 2.306E11 m/s². The correct kinematic equation, v²(final) = v²(initial) + 2ax, was identified as the most efficient method to find the final velocity without needing to calculate time. The final speed of the proton was determined to be 2.92E4 m/s after correcting an initial miscalculation involving the squaring of the initial velocity.
  • Understanding of Newton's second law (F=ma)
  • Familiarity with kinematic equations
  • Knowledge of electric fields and their effects on charged particles
  • Basic proficiency in physics calculations involving acceleration and velocity
  • Review kinematic equations for motion under constant acceleration
  • Study the relationship between electric fields and force on charged particles
  • Practice problems involving Newton's second law and electric forces
  • Explore advanced topics in electromagnetism and particle dynamics
Students studying physics, particularly those focusing on electromagnetism and kinematics, as well as educators seeking to clarify concepts related to forces acting on charged particles.
Boozehound
A uniform electric field has a magnitude of 2.41E+3 N/C. In a vacuum, a proton begins with a speed of 2.27E+4 m/s and moves in the direction of this field. Find the speed of the proton after it has moved a distance of 1.85 mm.
alright i looked for some kinematics equations and i used v=d/t. then when i figured out time to be 8.149E-8 i plugged it into d=1/2(a)(t^2)+(v)(t). i found acceleration to be 2. once i get here I am stuck. any help to point me in the right direction would be a great help.
v=d/t does not work during acceleration. You need to think about what force is working on the proton and use Newton's second law to find the acceleration. After that, you can use kinematics. So, how do you think you can find the force of the electric field on the proton?
alright so if i use Newtons second law (F=ma) i would think that F is the electric field. so do i then take 2.41E3N/C and multiply it by 1.60E-19 so i would have just Newtons? and if i do that then would i use 1.672E-27kg for the mass of the proton?
Yes, that's the proper approach to find the acceleration.
alright thanks!
well i used Newtons 2nd law to find acceleration to be 2.306E11m/s^2. then i too that and plugged it into d=1/2(a)(t^2)+(v)(t) to solve for velocity. but when i got to put the answer i get into my program for school it tells me its wrong. so where am i going wrong?
What did you use for t? The value you found for t before is not valid. There is another kinematic equation that is more suitable.
BTW, you don't actually need to find t, there is an equation you can use to find the final velocity that doesn't involve time.
ok so i looked up even more kinematics equations and i came up with this
v^2(final)=v^2(initial)+2ax
v^2(final)=2.27E4m/s+2(2.306E11m/s^2)(.00185m)
and i get final velocity to be 2.92E4m/s then i took those answers and plugged them into x=1/2(v(initial)+v(final))t. and i get t to equal 7.129E-8s. and that doesn't sounds right at all. i mean granted its only moving 1.85mm but its a proton and that's a really fast time. this problem has been kicking my ass.
i saw your last post after i posted that. and i found the formula vf^2=vi^2+2ax and i plug in the numbers and i get 2.92E4m/s which is wrong. so I am thinking my acceleration is off.
This is all you need though. You want to find v(final), right? You know everything else in this equation. a you found by Newton's second law, v(initial) and x were given in the question.
I am thinking you didn't square v(initial) in your calculation. Try it again.
yeap..that was my problemo. ah how the little things can make things seem impossible. thank you very much!
You're welcome! :smile:
  • · Replies 33 ·
