Speed of an air molecule when transmitting sound of frequency f
The discussion revolves around the speed of air molecules in relation to the transmission of sound waves of frequency f. Participants explore the relationship between molecular speed, sound frequency, and amplitude, while addressing concepts of sound as pressure waves and the implications of molecular collisions.
  • Some participants assert that the speed of sound is constant regardless of frequency, questioning the relevance of individual air molecule speeds in sound transmission.
  • Others propose that the average speed of air molecules might increase with frequency, suggesting a relationship between molecular motion and sound energy.
  • A participant mentions that sound waves are pressure/density waves, indicating that the net velocity of air molecules is zero despite their oscillatory motion.
  • One participant seeks an equation relating the average velocity of molecules to frequency, referencing the concept of molecular collisions.
  • Another participant suggests looking into heat transfer literature for insights on molecular behavior, particularly regarding mean free path.
  • Some participants discuss the distinction between amplitude and wavelength, with conflicting views on their relationship to frequency.
  • There is mention of the average speed of gas molecules being close to the speed of sound, yet acknowledging that individual molecular speeds may vary locally with frequency changes.
Participants express differing views on the relationship between molecular speed, frequency, and amplitude. There is no consensus on how these factors interact, and the discussion remains unresolved with multiple competing perspectives.
Participants highlight the complexity of sound transmission, including the effects of temperature on molecular speed and the implications of pressure waves. There are unresolved questions regarding the definitions and relationships of amplitude, frequency, and wavelength.
This discussion may be of interest to those studying acoustics, thermodynamics, or molecular physics, particularly in understanding the dynamics of sound transmission in gases.
  • #31
According to their logic the average speed is 4Af and the the max speed is 2πAf.
The average speed is wrong, thus the max speed most probably wrong for the same reasons. Because when f tends to zero, the speed does not tend to zero.
Also, if we consider A to be the actual displacement of the molecule, then the factor A is correct. But we consider that when there is no sound, A is zero, thus the factor A is also wrong.
I guess these equations would be correct if the molecule was still when there is no sound.
The molecule is making a difinite number of oscillations (which is not definded by f) within a definite distance (which is not 2A) in each sec, when there is no sound.
Therefore, someone must find the correct equation. If I am wrong show me why.
My mistake could be that we can consider the speed of the molecule as zero when there is no sound, but why-how? Vin, don't say again that the average speed is zero "in all directions", because according to this logic, the speed in the above equations should also be zero.
  • #32
I was just walking back from the library restrooms and noticed a book called, "A Textbook of Sound" and immediately thought back to this thread. I have just picked out some passages that I looked quickly at. Take it for what it's worth.
"A Textbook of Sound" 3rd Rv. A.B Wood cpyrt 1955. G.Bell and Sons Ltd.
Pg 248 - 249 "velocity of small amplitude waves" excerpts
[tex]\sqrt{\overline{u^2}}=482 metres/sec[/tex]
= root mean square velocity ;
[tex]\bar{u}=447metres/sec[/tex]
= mean velocity of molecules
The Kinetic Theory of Gases shows very simply that the pressure in a gas is given by
[tex]P=\frac{1}{3}Nm\overline{u^2}=\frac{1}{3}\rho\overline{u^2}[/tex]
where [tex]\\N[/tex] is the number of molecules per c.c., [tex]\\m[/tex] the mass of a molecule, and [tex]\rho[/tex] the density of the gas.
This relation expresses the molecular velocity in terms of the pressure and density of the gas, thus
[tex]\overline{u^2}=\frac{3P}{\rho}[/tex]
Since the energy of the motion of the molecules in a given (i.e. x-axis) we may write
speed of sound = [tex]\sqrt{\overline{u_{x}^2}}=\sqrt{\frac{P}{\rho}}[/tex]
Which is Newton's "Isothermal Velocity" of wave-propagation in the gas. If we employ the mean molecular velocity [tex]\bar{u}[/tex] instead of [tex]\sqrt{\overline{u^2}}[/tex]
we find
[tex]\sqrt{\overline{u^2}}=\bar{u}\sqrt{\frac{3\pi}{8}}[/tex]
Pg 275-276 "Velocity of Sounds of High Frequency -- in Gases" excerpt
H.O. Kneser, in a number of theoretical and experimental papers dealing with anomalous absorption and dispersion of sound, has derived the following expression for the velocity in terms of frequency, [tex]\\w=2\pi\\N[/tex], and molecular constants:
[tex]\\v=\sqrt{\frac{P}{\rho}}\left(1+R\frac{c_{v}+w^2\beta^2c_{va}}{c_{v}^2+w^2\beta^2c_{va}^2}\right)[/tex]
where [tex]\\c_{v}[/tex] is the molecular heat at constant volume, [tex]\\c_{va}[/tex] is the specific heat of the translation degrees of freedom, [tex]\\R[/tex] is the universal gas constant, and [tex]\beta[/tex] is the mean life of the energy-quantum, that is the time involved in the quantum transformation -- translational-intramolecular-translational energy.
at low frequencies the velocity becomes [tex]\sqrt{\frac{P}{\rho}}\left(1+\frac{R}{c_v}\right)[/tex]
whereas at high frequencies it becomes [tex]\sqrt{\frac{P}{\rho}}\left(1+\frac{R}{c_va}\right)[/tex]
Anyways it appears to me that you should be able to substitute around and solve for molecular velocity
  • · Replies 31 ·
  • · Replies 23 ·
  • · Replies 49 ·
  • · Replies 23 ·
