Speed of electron in electric field question
The discussion revolves around calculating the speed of an electron released between two positive point charges. Initial calculations using net force and acceleration yield an implausible speed. A suggestion is made to apply electric potential and conservation of energy instead, resulting in a potential difference of 183.1V. The energy gained by the electron is calculated, leading to a speed of approximately 8.02x10^-6 m/s. Participants emphasize the importance of accurate unit handling and the need for careful verification of calculations before submission.
lowcard2
Two stationary positive point charges, charge 1 of magnitude 3.55 and charge 2 of magnitude 1.60 , are separated by a distance of 55.0cm. An electron is released from rest at the point midway between the two charges, and it moves along the line connecting the two charges.
What is the speed of the electron when it is 10.0 from charge 1?
The attempt at a solution
Fnet = kQe/r² - kqe/r² = [(9x10^9)(1.6x10^-19)/0.275²][3.8 - 2]x10^-9
Fnet = 3.71x10^-17
a = Fnet/m = 4.076x10^13
t² = 2ax = 2.855x10^6
t = (10^6)√6.32 = 2.855x10^6 m/s
v(x) = 2.855x10^6 m/s x 4.076x10^13
but answer doesn't make sense
thank you all for your time
Fnet = 3.71x10^-17
Hello lowcard2. Welcome to PF !
As the electron moves, the force on it changes, and therefore so does it's acceleration.
I suggest doing this problem using electric potential & conservation of energy.
thank you for the welcome!
forgot to include units in question. nC charges and cm distances
can someone check this?
Potential at a point: V = kq/r.
Relative to charge 1, the potentials are V1i = (9x10^9)(3.55)(10^-9)/(0.275) = 116 volts before, and
V1f = (9x10^9)(3.55)(10^-9)/(0.10) = 3.20x10^11319.5volts after.
Potential difference: 203.5V
Relative to charge 2, V2i = (9x10^9)(1.60)(10^-9)/(0.275) = 52.4 volts before, and
V2f = (9x10^9)(1.60)/(0.45) = 32 volts after.
Potential difference: -20.4V
Those differences are in opposite directions (one pulls left, the other right), so 203.5 -20.4V = 183.1V
Energy gained by an electron traveling down that gradient: qV = (1.6x10^-19)(183.1) = 2.93x10^-17 joules.
2.93x10^-17 = 1/2(9.11x10^-31kg)v^2
v=8.02x10^-6
v=8.02x10^-6
How can you divide something on the order of 10-17 by something on the order of 10-34 and wind up with something much less than 1 ?
sorry that's not supposed to be ^-6. its positive
any input would be great. I only have one submission left so i have no room for error
i have a couple hours to submit. any more comments? thank you guys
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
