I Beyond the Speed of Light: Objects Beyond the Observable Universe
Sachabloke
Are objects beyond the observable universe in some sense moving faster the the speed of light. Given that objects at the edge of the observable universe are "maximally" red shifted, objects beyond that theoretically must be more red shifted, which is impossible. Is it therefore a nonsense to believe that anything exists beyond 13.8 billions light years away? I understand the answer is no, but I thought it an interesting topic.
Only in a coordinate dependent sense which has no physical relevance. If you want to be rigorous, there is no way of saying that two objects are moving with a particular relative speed unless they are at the same place (or sufficiently close so that spacetime can be considered locally flat).
This is a logical fallacy. It only means that the light from those objects will never reach you - which is the same statement that you started with.
Likes vanhees71
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
