Electric Field Uniformity in a Sphere with Cavity
In summary, the problem involves a solid sphere with a uniformly distributed charge and a spherical cavity cut out of it. The material and its charge are discarded. The goal is to show that the electric field in the cavity is uniform with a magnitude of kqd/r^3, where d is the distance between the centers of the spheres. The principle of superposition and the equation E=kq/r^2 are used to calculate the electric field at the center of the small sphere. This method can then be extended to any point in the small sphere to show that the field is uniform due to the cancellation of field vectors in opposite directions.
phantom113
A charge q is uniformly distributed over the volume of a solid sphere of radius R. A spherical cavity is cut out of this solid sphere and the material and its charge are discarded. Show that the electric field in the cavity will then be uniform, of magnitude kqd/r^3, where d is the distance between the centers of the spheres.
E=kq/r^2
I'm not really sure where to start with this one. I know you can take the electric fields of the two spheres and add them together, but the cavity has no charge enclosed. Maybe I'm just reading the problem incorrectly. A push in the right direction would be terrific.
Thanks.
I noticed that it is easy to calculate the E field at one particular point - the center of the small sphere. The total E is the E due to the big sphere (with no hole) minus the E due to the small sphere of charge.
Perhaps you can extend the method to any point in the small sphere . . .
OK, thanks I got the equation to work(had to assume that one part of edge of the cavity was also the edge of the sphere to get the radius of the cavity). Is the reason that it's a uniform field that the field vectors at a random point not in the middle are in opposite directions and end up canceling to the same value as the field at the middle?
1. What is a "sphere of charge with cavity"?
A sphere of charge with cavity is a theoretical concept in electrostatics where a hollow sphere is charged with a net charge on its surface, while there is an empty space or cavity inside. This configuration allows for the electric field to be calculated both inside and outside the sphere.
2. How does the presence of a cavity affect the electric field inside the sphere?
The presence of a cavity in a charged sphere changes the distribution of charge on the surface, resulting in a different electric field inside the sphere compared to a solid charged sphere. This is due to the fact that the electric field lines are distorted by the presence of the cavity, causing a non-uniform distribution of charge on the inner surface of the sphere.
3. Can the electric field inside a sphere of charge with cavity be zero?
Yes, it is possible for the electric field inside a sphere of charge with cavity to be zero. This occurs at the center of the cavity, where the electric field from the charged surface of the sphere and the electric field from the inner surface of the cavity cancel each other out.
4. How is the electric potential inside a sphere of charge with cavity related to the electric potential outside the sphere?
The electric potential inside and outside a sphere of charge with cavity is related by the equation V_inside = V_outside + kQ/R, where V_inside is the electric potential inside the sphere, V_outside is the electric potential outside the sphere, k is the Coulomb constant, Q is the charge on the sphere, and R is the radius of the sphere.
5. What is the significance of a sphere of charge with cavity in practical applications?
Sphere of charge with cavity is a theoretical concept that helps in understanding the behavior of electric fields and potentials in a non-uniformly charged object. It can be applied in the study of capacitors, electric shielding, and other practical devices that involve charged spheres with cavities.
