What Are Spin-Up Effects in Waterwheels and Their Impact on Inertial Damping?
  • Context: Graduate
  • Thread starter Thread starter broegger
    Effects
Spin-up effects in waterwheels refer to the inertial damping caused by the interaction between the wheel and water particles. As water enters the wheel at zero angular velocity and exits at a non-zero angular velocity through holes in the papercups, it imparts momentum to the water, resulting in a reactive force on the wheel. This reactive force, quantified as the product of mass flow rate and exit velocity, generates torque that counteracts the wheel's angular velocity. The support structure of the wheel plays a crucial role in preventing displacement due to the forces from ejected water particles.
  • Understanding of Newton's Third Law of Motion
  • Familiarity with concepts of torque and angular velocity
  • Basic knowledge of fluid dynamics, particularly mass flow rates
  • Experience with mechanical systems involving damping forces
  • Study the principles of fluid dynamics in mechanical systems
  • Learn about the mathematical modeling of torque in rotating systems
  • Explore the effects of mass flow rates on system dynamics
  • Investigate various types of damping in mechanical engineering applications
Mechanical engineers, physicists, and students studying fluid dynamics or mechanical systems will benefit from this discussion, particularly those interested in the dynamics of waterwheels and inertial damping effects.
broegger
Hi.
Can anyone explain to me what spin-up effects are? The context is a waterwheel that consists of an ordinary wheel with papercups with holes in the bottom suspended along the rim. It is stated that for this wheel there are two sources of damping: ordinary frictional damping and "inertial" damping which is caused by a spin-up effect. This is due to the fact that water enters the wheel at zero angular velocity but is thrown out at non-zero angular velocity through the holes in the bottom of the cups. How does this produce inertial damping?
broegger said:
Hi.
F = ma = dp/dt = vdm/dt
So if the water wheel is throwing off mass at a certain rate, there will be an inertial force on the wheel.
AM
Since, effectively, the water wheel imparts momentum to the water particles during the contact phase, it follows that the water particles "kick back" on the wheel, according to, for example, Newton's 3.law.
That kick-back is inertial damping of the wheel.
Quantitatively, the net force is typically the product of the mass flow rate and the exit velocity.
Note:
It is, of course, the TORQUE produced by this force that tends to counter-act the wheel's angular velocity.
In addition, the support structure of the wheel prevents wheel from being displaced as a result of the force from the ejected water particles.
  • · Replies 64 ·
