Spinning top undergoing nutation
  • Thread starter Thread starter techmologist
    Spinning
The discussion centers on the behavior of a symmetric top undergoing precession and nutation under gravitational torque. It questions whether the spin rate of the top remains constant or varies over time, assuming a frictionless pivot point. The spin rate is suggested to change periodically to conserve energy as the top nutates. The conversation reflects on the complexities of understanding the motion of a heavy top using basic principles of torque and energy conservation. Resources for deeper exploration of the topic beyond basic equations of motion are also sought.
techmologist
Suppose you have a symmetric top precessing and nutating under the torque due to gravity. My question is this: does the spin rate of the top (the rate at which it spins on its axis of symmetry) vary with time or is it constant? I am assuming the 'foot' of the top is fixed and that the motion about this fixed point is frictionless.
As the top nutates, The spin rate changes periodically to conserve energy.
Thanks for the reply, clem. I have been trying to understand the motion of a heavy top by freshman-level methods, namely, requiring that all the torques on individual mass elements of the top add up to the torque of gravity. This technique works well for the case of torque-free precession, where you can guess what the motion looks like. In that case the spin rate is constant, and I just assumed it was for a heavy top, too. I had also assumed the faster precession rate at the low point in the nutation cycle was enough gain in kinetic energy to balance the loss of potential energy. For some reason, I can't help but think of the spin rate as a kind of "intrinsic" property of the top. After all, it was determined when you twisted it with your thumb and forefinger, or pulled the string in the case of a gyroscope. How does the top "know" to speed up and slow down its spinning as it bobs up and down? I know that's a silly question, but I still find this periodic spin rate kinda spooky. Do you know of any book or website that gives an explanation of this beyond just solving the equations of motion?
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
