GiTS
- 132
- 0
I'm not usually into the "green" thing, but an unrelated interest brought me to the topic of spiral heat exchangers and I also received some encouragement.
The idea is a small, low cost spiral heat exchanger for use in village sized water treatment, desalination, and for making showers "greener" by recycling heat.
In my mind I'm thinking a thin aluminum (about soda can thick) sheet coiled around two pipes then the ends are weld to the side to make the spiral shape. It's kept in that shape simply due to spring force. Thin stamped sheet metal or plastic end caps with a rubber gasket are clamped onto the spiral and attached with either metal wire (like a drum) or screwed together with long rods or hollow tubes. The pipe fittings are all on the faces.
I would like a design that is very cheap to automate with existing equipment. Thoughts? I know very little about the manufacturing process when it comes to relative costs. I know how to get quotes on molded plastic parts but not the metal working processes.
Any engineers out there know how this could be done? Is there a good manufacturing forum to send this inquiry to? Is there a no hassle way to get metal work quotes?
Many Thanks
-GiTS
Many Thanks
-GiTS
