Spivak Calculus: Problem 1-(iii)
  • Thread starter Thread starter Saladsamurai
    Calculus Spivak
Saladsamurai
Prove that if x2 = y2 then x=y or x = -y
The 12 Properties of numbers
I think I should do this case-wise:
Case (a) if x=y then x2 = x*x=y*y=y2. Simple enough.
Case (b) if x = -y then x2 = x*x=(-y)*(-y) = ...
So what is left to show is that (-y)*(-y) = y*y which is where I am getting stuck.
I was thinking of doing something like:
(-y)(-y) = (-y)(-y)*1 = (-y)(-y) * [(-y)(-y)]*[(-y)(-y)]-1
... but I don't see this going anywhere really. Any thoughts?
I think you are actually doing the thing a bit backwards. If x^2=y^2 then x^2-y^2=0=(x-y)(x+y). You should be able to prove that from the 12 properties of numbers, whatever they are. You should also have if a*b=0 then a=0 or b=0. Try it that way.
Hmmm... After some searching around, it seems that my approach might not be the best. The simplest, is to use the given information:
x2 = y2
x2 - y2 = y2 - y2 = 0
so
x2 - y2 = x2 +xy - xy - y2
(x+y)*(x-y) = 0
from here it is easy enough to show that since (x+y) or (x-y) is zero, then x = y or x = -y.
Does this mean that the original way I was trying never would have panned out? I think it can still be done. I am just having trouble trying to prove that:
(-a)(-a) = aa
in a rigorous way. Though I feel like I have done this. Actually, Spivak does prove this on page 7:
(-a)*a + a*a = a*[(-a) + a] = a*0 = 0
Adding -(a*a) to both sides:
(-a)*a + a*a + -(a*a) = -(a*a) so that
(-a)*a = -(a*a)
now adding (-a)*(-a) to both sides:
(-a)*a + (-a)*(-a) = -(a*a) + (-a)*(-a)
factor:
(-a)*[(-a) + a] = -(a*a) + (-a)*(-a) or
-(a*a) + (-a)*(-a) = 0
Finally, add a*a to both sides:
a*a + -(a*a) + (-a)*(-a) = 0 + a*a
so that:
(-a)*(-a) = a*a.
yay!Edit: Hi Dick! By "backwards" do you just mean "not the way I would do it" ? Or do you mean wrongwards? Just curious. Either way, I am satisfied with the answer!
Well, what you proved using your original method is that if x=y or x=-y, then x^2 = y^2. It's TRUE, but it's the converse of what you're trying to prove.
What Char. Limit has pointed out is what I meant by backwards. Proving x=y and x=(-y) are solutions doesn't prove there might not be other solutions. Doing it forwards does.
I see. Thanks for the tips! I got a lot of mileage out of this one.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
