Splitting the tim eindependent schroedinger equation
  • Thread starter Thread starter Mechdude
    Splitting
Mechdude
splitting the time independent schroedinger equation
how would i go about splitting the time independent Schroedinger equation into 3 separate 1-D problems of the main 3-d problem whose total energy is E = E_x + E_y + E_z ?
\frac{-\hbar^2}{2m} \frac{ \partial^2 \Psi(x) }{\partial x^2} + V(x) \Psi (x) = E \Psi(x)
assuming:
\Psi (x) = R(x) S(y) J(z)
i want to assume that V(x) remains a function of x alone and only \Psi(x) is a function of x,y,z , I am i right? and further more what do i do to the expression to show that the variables are independent of each other? in solving the heat equation we would differentiate the stuff and find that the two sides were independent (one on time the other on position) is that what is done here? or is there some analogous way to do that?
EDIT:
sorry about the \Psi (x) [/tex] it should be \Psi (r) <br /> <br /> from the defenition of \nabla^2 and separating the solution into a product of three functions R(x)S(y)J(z) :<br /> <br /> this is what i get as the equation in cartesian coordinates,<br /> \frac{-\hbar^2}{2m} \left[ S(y) J(z) \frac {\partial^2 R(x)}{\partial x^2} + R(x)J(z) \frac {\partial^2 S(y)}{\partial y^2} + R(x)S(y) \frac{\partial^2 J (z) }{\partial z^2} + V(r) R(x)S(y)J(z) = E R(x)S(y)J(z) \right] <br /> dividing through by R(x) S(y) J(z) and multiplying by \frac{-2m}{\hbar} <br /> \left[ \frac{ \partial^2 R(x}{R(x) \partial x^2} + \frac{ \partial^2 S(y)}{S(y) \partial y^2} + \frac { \partial^2 J(z) }{ J(z) \partial z^2} \right] -\frac{2m V(r)}{\hbar^2} = -\frac{E 2m}{\hbar^2}<br /> <br /> im stuck from here on how to show that it can be separated into two separate independent variables and equation.
You need the potential to be of the form V(x,y,z)=Vx(x)+Vy(y)+Vz(z), e.g., the potential for the three-dimensional harmonic oscillator is V(x,y,z)=(k/2)(x2+y2+z2). Then you can rewrite the equation into three pieces, each depending on only one variable.
thanks vela , now if i modify it , what actually inspires the spit into separate equations? is it because the x ,y and z are not dependent on each other?
<br /> \left[ \frac{ \partial^2 R(x}{R(x) \partial x^2} + \frac{ \partial^2 S(y)}{S(y) \partial y^2} + \frac { \partial^2 J(z) }{ J(z) \partial z^2} \right] -\frac{2m V_x (x) V_y (y) V_z (z)}{\hbar^2} = -\frac{E 2m}{\hbar^2} <br />
Reread what I wrote about the form of the potential more carefully.
let me give it one more try:
is this what you meant,
<br /> <br /> \left[ \frac{ \partial^2 R(x}{R(x) \partial x^2} + \frac{ \partial^2 S(y)}{S(y) \partial y^2} + \frac { \partial^2 J(z) }{ J(z) \partial z^2} \right] -\frac{2m (V_x (x) + V_y (y) +V_z (z))}{\hbar^2} = -\frac{E 2m}{\hbar^2} <br /> <br />
if that's what you meant ,then its my bad, i did not read you post carefully.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
