Spontaneous symmetry breaking in SHO
Spontaneous symmetry breaking occurs when a system's solution loses symmetry present in its Lagrangian, a concept rooted in quantum mechanics rather than classical mechanics. The Simple Harmonic Oscillator, while exhibiting periodic solutions, maintains time translational invariance in its Lagrangian, thus does not demonstrate spontaneous symmetry breaking. In quantum mechanics, superpositions of solutions can be formed, but this is not the case for the harmonic oscillator. True spontaneous symmetry breaking requires systems with infinite extent, such as magnets composed of numerous spins. Therefore, the harmonic oscillator does not exemplify spontaneous symmetry breaking.
Shadumu
Spontaneous symmetry breaking refers to the solution of a system loses some symmetry in its Lagrangian. Consider a Simple Harmonic Oscillator, its lagrangian is time translationally invariant but its solution is periodic in time, thus not time-translational invariant. Is this Spontaneous symmetry breaking?
No, it is not. The concept of spontaneous symmetry breaking is a concept from quantum mechanics (QM) rather than classical mechanics. The point is that in QM, you can usually form superpositions of solutions of the equations of motion and they will be solutions again. In the case of the harmonic oscillator, you can form any superpositions of the different solutions which aren't completely symmetric. The point of spontaneous symmetry breaking is that this possibility to form superpositions of solutions of different symmetry is no longer possible. For an harmonic oscillator, this is not possible. Rather, it requires systems of infinite extent, like for example a magnet which is built up of an infinite number of spins.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
