Revolutionizing Everything: Spray-on Liquid Glass
In summary, the study found that people who consume more silica have a reduced risk of developing dementia, but drinking water from a location with high aluminum levels does not appear to play a role.
rolls
52
Spray-on liquid glass is about to revolutionize almost everything
(PhysOrg.com) -- Spray-on liquid glass is transparent, non-toxic, and can protect virtually any surface against almost any damage from hazards such as water, UV radiation, dirt, heat, and bacterial infections. The coating is also flexible and breathable, which makes it suitable for use on an enormous array of products.
...Liquid glass spray is perhaps the most important nanotechnology product to emerge to date. It will be available in DIY stores in Britain soon, with prices starting at around £5 ($8 US). Other outlets, such as many supermarkets, may be unwilling to stock the products because they make enormous profits from cleaning products that need to be replaced regularly, and liquid glass would make virtually all of them obsolete.
http://www.physorg.com/news184310039.html
On the company's website it states;
Certificates and expert’s reports by accredited independent institutes and labs have documented the following properties:
* Physiological harmless
* Food safe
* Compatible with skin and mucosa
* Free of nano particles
* Environmentally friendly
http://www.nanopool.eu/couk/ultra_duenn.htm
So what do you guys think, is this a load of bollocks? Or is it entirely plausible and will likely become a revolutionary product?
Also what would happen if you people started spraying it on food and fruit. Would you wear the enamel on your teeth away faster? What would happen if it got into your lungs? Could it crystallise and turn into nano shards like asbestos?
Discuss.
Late edit by Ivan: Please quote only excerpts in order to avoid copyright infringement.
Definitely an interesting product if the claims are true.
Should be available for purchase/testing soon.
SiO2, except for inhalation, is innocuous. Inhaled, it causes silicosis. It is a component of the mineral asbestos that is particularly hazardous for various mechanical properties.
I can imagine flakes of this glass coating having similar mechanical properties to asbestos.
http://aje.oxfordjournals.org/cgi/content/abstract/169/4/489
Conversely, an increase of 10 mg/day in silica intake was associated with a reduced risk of dementia (adjusted relative risk = 0.89, P = 0.036). However, geographic exposure to aluminum or silica from tap water was not associated with dementia.
Related to Revolutionizing Everything: Spray-on Liquid Glass
1. What is spray-on liquid glass and how does it work?
Spray-on liquid glass is a revolutionary technology that involves applying a thin layer of liquid glass to a surface using a spray or wipe-on method. The liquid glass is made up of tiny particles of silicon dioxide, which form a protective layer when applied. This layer acts as a barrier against water, dirt, and other contaminants, making the surface more durable and resistant to damage.
2. What are the potential applications of spray-on liquid glass?
The potential applications of spray-on liquid glass are vast and diverse. It can be used on various surfaces, including glass, metal, plastic, and even fabrics. Some potential applications include coating electronic devices for waterproofing, protecting buildings from corrosion and graffiti, and improving hygiene in healthcare settings by creating a self-cleaning surface.
3. Is spray-on liquid glass safe for the environment?
Yes, spray-on liquid glass is considered environmentally friendly. The liquid glass particles are non-toxic and biodegradable, so they do not harm the environment. Additionally, the use of spray-on liquid glass can reduce the need for harsh chemicals and cleaning agents, which can be harmful to the environment.
4. How durable is spray-on liquid glass?
Spray-on liquid glass is incredibly durable, with a lifespan of 3-5 years on most surfaces. It can withstand extreme temperatures, UV radiation, and abrasion, making it an ideal choice for outdoor applications. However, the durability may vary depending on the surface and the number of coats applied.
5. Can spray-on liquid glass be applied by anyone, or is it a specialized process?
While spray-on liquid glass is relatively easy to apply, it is recommended to have it done by a professional for best results. The process involves cleaning the surface, applying the liquid glass, and buffing it to a smooth finish. It is essential to follow the instructions carefully and wear protective gear during the application process.
