Solving a differential equation: f = ma, f = -kx -bv
In summary, to rearrange f = ma and f = -kx - bv into the form of a differential equation, we need to find the characteristic equation by setting k/m = ω_n^2 and b/m = 2ζω_n. Then, we can find the roots of the characteristic equation and use them to write the solution to the differential equation as x(t) = Ae^(-ζω_n t)cos(ω_d t + φ), where ω_d = ω_n√(1-ζ^2) and A and φ are determined by the initial conditions. Understanding the concept of characteristic equations is important in solving linear homogeneous differential equations.
DaveMan
so, f = ma, and f = -kx -bv.
rearrange to the form of a differential equation.
i am stuck when the next line simply states the general solution.
i have done this for first differential only, not second derivatives.
please help!
For the homogeneous solution to ma = -kx -bv, it is standard practice to find the characteristic equation:
First, rewrite into a standard form:
[itex] \ddot{x} + \frac{b}{m}\dot{x} + \frac{k}{m}x [/itex]
Set
[itex] \frac{k}{m} = \omega_n^2 [/itex]
[itex] \frac{b}{m} = 2\zeta\omega_n [/itex]
(the reason why should be clear by the end of the problem; natural frequency and damping ration are useful, meaningful quantities in the study of oscillations)
[itex] s^2 + 2\zeta\omega_n s + \omega_n^2 = 0 [/itex]
find the roots of the characteristic equation (it's just a quadratic in s), s 1,2 , so that the solution to the differential equation is written:
[itex] x(t) = C_1 e^{s_1 t} + C_2 e^{s_2 t} [/itex]
using the Euler identity and some algebra, you end up with the solution:
[itex] x(t) = A e^{-\zeta\omega_n t}\cos\left(\omega_d t + \phi \right) [/itex]
where the damped frequency [itex] \omega_d = \omega_n \sqrt{1-\zeta^2} [/itex] and the constants A and φ (magnitude and phase) are determined by the initial conditions. (You can solve it with a sine or cosine, you'll just end up with a different phase.) That's just the basics off the top of my head, but I hope that helps.
I don't understand how you get the charateristic equation.
That's usually one of the first things you learn in an introductory differential equation course.
The linear homogeneous differential equation a y"+ by'+ cy= 0 has
"characteristic equation" ar2+ br+ c= 0.
More generally, you replace the nth derivative with rn.
What is a differential equation?
A differential equation is a mathematical equation that describes how a quantity changes over time or in relation to another quantity. It involves derivatives, which represent the rate of change of the quantity, and can be used to model various physical phenomena.
What is the significance of the equation f = ma?
The equation f = ma, also known as Newton's second law of motion, relates an object's force (f) to its mass (m) and acceleration (a). It is a fundamental equation in classical mechanics and is used to calculate the motion of objects under the influence of forces.
What does the equation f = -kx - bv represent?
The equation f = -kx - bv is known as the equation of motion for a damped harmonic oscillator. It describes the relationship between the force (f) acting on the oscillator, the displacement (x) of the oscillator from its equilibrium position, and the damping coefficient (b) and spring constant (k) of the oscillator.
How do you solve a differential equation?
Solving a differential equation involves finding a mathematical expression that satisfies the equation. This can be done analytically by using integration, or numerically by using numerical methods such as Euler's method or Runge-Kutta methods. The specific method used depends on the complexity of the equation and the desired level of accuracy.
What are some real-life applications of solving differential equations f = ma and f = -kx - bv?
The equations f = ma and f = -kx - bv have many real-life applications. For example, they can be used to model the motion of a pendulum, the oscillation of a mass on a spring, or the movement of a vehicle on a bumpy road. They are also used in fields such as engineering, physics, and economics to predict and analyze the behavior of systems under the influence of forces.
  • Differential Equations
