Spring force with free fall problem
The problem involves a 2.50 kg mass compressing a spring and then sliding on a table before falling off. The mass experiences kinetic friction and hits the ground with a speed of 6.64 m/s. The discussion clarifies that the scenario is not purely a free fall problem, as the horizontal speed at the edge of the table affects the fall. The calculation for the height of the table, ∆y, is derived using the equation Vf^2 = Vi^2 - 2g∆y, resulting in a height of approximately 2.25 meters. Ultimately, the problem is framed as one of projectile motion, emphasizing the need to consider the horizontal velocity upon leaving the table.
scarne92
Consider the system below. The 2.50 kg mass compresses the spring (k = 805 N/m) a distance of 0.230 m from equilibrium. The mass is then released from rest. It slides a total distance of 1.20 m on the table top where it feels a force of kinetic friction of 5.60 N before it slides off the edge. If it hits the ground with a speed of 6.64 m/s, find the height ∆y of the table.
Vf^2 = Vi^2-2g∆y
I started doing the spring force part of the problem, but then the thought hit me that the speed shouldn't matter in the x direction because it is just a free fall problem. I'm not sure if I'm correct in that thinking though.
here's what I got.
∆y = (Vf^2 - Vi^2)/-2g
∆y = (6.64^2 - 0^2)/-2(9.81)
∆y = 44.0896/-19.62
∆y = 2.25m
Vf^2 = Vi^2-2g∆y
here's what I got.
∆y = 44.0896/-19.62
∆y = 2.25m
It is not a simple free fall problem.
If the mass just tipped over the edge, it just falls to the floor reaching a speed of 6.64
If however the mass leaves the table traveling at a speed of 6.6 m/s, it will have gained the extra 0.04 m/s by falling just a few mm.
In the end this is a projectile motion question: you have to work out how fast the mass is traveling when it leaves the table.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
