Square steel tubing for a beam....did I do this right?
  • Thread starter Thread starter Ross C
    Square Steel
The discussion revolves around the design and structural integrity of square steel tubing beams intended to support a large steel box over a hole. Participants explore calculations related to stress, yield strength, and deflection, as well as the implications of these factors on the safety and functionality of the beam setup.
  • One participant outlines the dimensions and weight of the steel box, detailing the setup for the beams and the calculations for stress and section modulus.
  • Another participant emphasizes the importance of estimating deflection alongside stress when designing beams.
  • Concerns are raised about the yield strength of the steel tubing, with references to ASTM standards and the need to verify material properties with suppliers.
  • Participants discuss the practical implications of beam deflection, including stability, adequacy for load support, and potential oscillation issues.
  • There is a query about how to determine acceptable levels of deflection, with suggestions that both scientific calculations and common sense should guide this assessment.
  • One participant suggests a rough guideline for acceptable deflection based on a percentage of the beam length.
Participants express varying levels of confidence in the calculations and assumptions presented, with no clear consensus on the adequacy of the proposed beam design or the specific acceptable limits for deflection.
Participants mention the need for accurate material properties and calculations, indicating that assumptions about yield strength and deflection limits may vary based on specific conditions and definitions.
Individuals involved in structural engineering, construction, or DIY projects requiring knowledge of beam design and load calculations may find this discussion relevant.
Ross C
I need to come up with a beam (two of them, actually) that will hold a large steel box suspended over a hole in which it will ultimately be buried. The box is 9 feet long by 5'6" wide and weighs 1600 pounds. The box will not rest across the length of the beam, it has to rest on two supports on either side. The hole will be just over 6 feet wide, so my beams will rest on the edge of the hole, and the box on the supports on the beam. A rough diagram:
==|=====||=================||====|== Beam
Hole Support Support Hole
edge edge
The hole will be 73 inches wide, the bar 85 inches, and the support rails 18 inches inside the edge of the hole. I added 25% to the weight of the box for safety and I think 2-inch square tubing with 1/8 inch walls will work - I found formulas to calculate the stress on the beam in this scenario and then some more to calculate the stuff the formulas need: section modulus came out to 0.5517, weight on the support 500 lbs (2000 / 4 supports), so a bar that long with the stress 18" from the end should be feeling 16,311 lbs/sq. inch. (right? I assumed the part of the bar outside the hole would not factor into the calculation...)
The challenge I had was finding out the yield strength (I hope that's correct - I'm looking for how much stress it can take without being ruined) of that material...came up with nothing beyond a vague post that 36000 psi is as far as you want to go for 'steel'. So, it looks like my 2" tube will work, but I'm not an engineer and am skeptical of both my calculations and the information I found. So I'm asking professionals...what do you think?
edge edge
I think your setup is thus:
Code:
     ------------ Box ----------------         Box = 2000# (1600# + 25%)
    18"  ||                     ||   18"
==|======||=====================||======|==    Beam (1 of 2) L = 85" each
edge                                   edge
  |<-------------- 73" ---------------->|
You should check with a supplier to obtain the correct material properties for the steel tubing sizes you select. Regular structural steel is ASTM A36, which has a yield stress of 36,000 psi, but steel tubing is often fabricated from higher-strength steels, like ASTM A500 or A513, which is why you should check before you buy.
Nidum said:
https://www.engineersedge.com/beam_calc_menu.shtml
Always estimate deflection as well as stress when designing beams
OK - I saw formulas for that...but why? Once I learn how much the bar will bend, what will I do with that information? Educate me, please?
Sorry for delay in replying .
There are several reasons to consider deflection of beams :
(1) Simple practicality . If beam deflects a lot then it isn't going to do the job of supporting your load .
(2) Beams which deflect a lot are usually an indication of them being inadequate for strength . Some beam sections - like I beams - can also become unstable and buckle when they have large deflections .
(3) Beams which deflect a lot are often very 'springy' and if suporting a ponderous load the whole lot might start to oscillate .
Generally deflections of a safe design of beam are very small compared to length of beam .
Not very scientific but always ask yourself whether you would be happy to stand underneath any steelwork carrying a heavy load !
That seems reasonable, but how do I know if my beam is bending 'a lot' (Or 'too much' if we're getting down to brass tacks)? I assume there's some amount that's acceptable, but how can I figure out the beam's deflection is acceptable?
Part scientific and part common sense - if it bends enough to see then it's too much .
For your arrangement say 0.1% of beam length or about 2 mm at mid point of beam .
  • · Replies 22 ·
18K
9K
