Square waves and nonlinear loads?
Nonlinear loads generate odd harmonics, which can alter the shape of a square wave input. When a square wave is applied to a nonlinear load, the output waveform will typically be modified and not retain its original square shape. The behavior of a nonlinear capacitor, such as a varactor, depends on the specific circuit configuration and can lead to the generation of new frequencies. While nonlinear loads can sometimes behave like linear loads within certain conditions, this is not universally applicable. Overall, the interaction between square waves and nonlinear loads is complex and varies based on the specific characteristics of the load.
hobbs125
Nonlinear loads produce odd harmonics which produce square waves.
What will happen if a square wave is pulsed into a nonlinear load?
Would the same square wave be seen across the load or would the nonlinear load change the square wave?
If a capacitor is nonlinear (i.e. capacitance changes with applied voltage) and a square wave is applied to it what would occur?
Define your non linear, it is such a general term. It's like saying the lens has distortion...what?...barrel, pinch cushion, chromatic aberration or what?!
This is not a true generalization.
Generally, the output will be a waveform altered in some way/s, i.e., it won't be a squarewave.
A varactor? The result depends on the circuit.
I think usually a nonlinear load is one that would have a non-linear "transfer function", where it can produce new frequencies not in the spectrum of its input signal. The problem with that is a transfer function is linear by definition, so it has to be described in other ways. An example would be considering a mixer as a nonlinear load. Basically, the system cannot be described by a set of linear equations, and so it cannot be solved to determine its output.
Nonlinear loads don't necessarily produce odd harmonics (not sure if you're using odd in the mathematical sense or in the verbal sense), and odd harmonics don't necessarily produce square waves. Odd harmonics can produce an infinite family of waveforms that are not square waves.
Your other questions give too general information to give you an answer, but its interesting to think about. A nonlinear load can look like a linear load within certain ranges, and so a square pulse in can be a square pulse out, but it wouldn't be true for all conditions. An example is a positive biased square pulse through a diode into a resistor, where its output would have the same frequency content as its input ideally. It is still a nonlinear system tho.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
