SQUID (superconducting quantum interference device)
A SQUID (superconducting quantum interference device) operates by utilizing a superconducting ring with two Josephson junctions to measure magnetic fields. When a magnetic field is applied, it alters the magnetic flux through the ring, leading to the generation of a screening current in the superconductor. This current creates a measurable voltage across the Josephson junctions, which is related to the strength of the magnetic field. Understanding the Josephson effect is crucial for grasping how SQUIDs function, as it underpins the principles of superconductivity and phase coherence. For a clearer grasp of these concepts, resources that explain superconductivity in simpler terms are recommended.
VenaCava
Hi all,
I am looking to do some magnetic measurements for some research (chemistry...) but I'm hoping to get an understanding of how a SQUID instrument works. I was wonder if anyone could give me a qualitative overview or if anyone know any resources without math-heavy explanations.
Thanks!
Wikipedia has a good, basic one-page description. Here's another site with good information
http://hyperphysics.phy-astr.gsu.edu/hbase/solids/squid.html
Since SQUID operation involves quantum mechanical concepts (electron wavefunctions, Cooper pairs and tunneling, e.g.), you can't get too deep without math.
Thanks. I've actually already taken a look at those.
I guess I just wanted some clarification on a few points since I don't have too strong of a physics background.
I understand that the squid detector has a superconducting ring with 2 Josephson junctions. The sample that the magnetic measurements are being taken for produces a magnetic field... which causes a change in magnetic flux through the superconducting ring. In response, the superconductor produces a screening current.
This (somehow??) results in the formation of a voltage across the Josephson junctions which can then be measured. What is the simplest explanation for how this happens?
Also is this voltage proportional to the magnetic field?? How exactly is information about the magnetic sample obtained from this voltage measurement.
Thanks
This is where you need to backtrack and see if you have understood the Josephson effect, because that is something that's used in SQUIDs. It's difficult to explain this right in the middle because one needs to understand a lot of concepts that LEADS to the physics of SQUIDs.
You may want to read this article to start with:
http://www.haverford.edu/physics/Amador/documents/01SQUID.doc
It teaches from, in elementary form, the physics of superconductivity (especially phase coherence which is central to SQUIDs) leading to why you need Josephson junctions.
Zz.
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
  • · Replies 30 ·
  • · Replies 60 ·
  • · Replies 21 ·
  • · Replies 76 ·
